I haven't heard yet, but have been too busy to ask.
I've annoyed Ben a fair bit lately asking about various changes, so one more "are we there yet" and it will probably come back in pieces, or worse making 140 KW.
Fingers crossed, accomm booked and leave pass organised.... :D
"Hi Ben, it's BBGTR here, is my car ready yet is my car ready yet?"
"140kw at the wheels you say? uhh ok"
thats fine with me! then you'll never catch me!!!! :(
  • Replies 96
I've just realised I need a new fire extinguisher after Winton's effort!! :D
Well it's all coming together.....
Hi all
Just a quick note to let you know that I have received and accepted your entries for the Piarc October Sprint,
Thank you for entering and I will see you on the Saturday and Sunday morning.
Gates open at 7am on Saturday and 8am on Sunday.
Regards
Theresa Ford
Sprint Secretary
Phillip Island Auto Racing Club
Everyone is dropping like flies! Aarons not making it, no idea if Jack is, Ben's obviously out as well. Haven't heard how Jesus is going either so I might yet have to wave the Vic skyline flag.
I WILL be there, brand new turbo sitting on Ben's desk ready to go in..... :D
Yep - I sent a bank cheque too... As did Fooey... Neither of us got a response.
Maybe they just took our cash and ran!?!?
No email either.
I sent a bank cheque so i wouldn't know if that went through either.
Andrew, was there a contact number on the confirmation email you received?
No email either.
Good to see you'll be down there Archie. As Snowy said, no ph. number unfortunately.
Wind the boost into that big single mate, and I'll sit behind for a tow!
Regards
Andrew
Thanks Bec
I emailed Theresa so I'll wait to see if i hear from her.
Andrew
LOL hardly. I saw your car last weekend and I know she's sorted now so if anyones going to be sitting behind it'll be me >_<
Still, I would love to follow you around to see the differences between our cars.
Well my car is on the back-burner cause of PI this weekend and the need to get a number of cars ready :sorcerer:
Not like i need it in a hurry anyhow lol.
So there should at least be a few going >_<
Yeah I got the same email yesterday, and I stated on the form that I'll pay cash on the day...
My car is finished and ready to go!!!!
Now with (a little) more power....
Can't wait to do another full track day...(fingers crossed)
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
