hey guys
just finished the following mods: 440cc inj, tomei fuel pump + fuel regulator, greddy emanage ultimate, prfect b. already have a cooler, pod, turbs back 3"exhaust. Am producing around 175kw. Looking at gettin more power without increasing the actual size of the turbo what would i go with next for more power? am open to high flowing but thats about it in the way of the turbo as i dont want it to stand out if being defected!
any ideas would be helpful and is this the amount of power youd expect with these mods?
cheers guys.
https://www.sau.com.au/forums/topic/187102-new-mods-completedwhat-next/
That is massive amounts of power out of a hyundai getz. :(
maybe you should update your cars section of you profile so that we know what you own and can better advise!!! :no:
lol...I have a getz aswell...dont bad the hyundai's...unless its an EXCEL!! :rofl:
Ryan
Not too sure what car you have, but i recently pulled 171kw at boostworx without larger injectors or a different ecu, would think you'd pull more than 4 extra kw with those mods but i could be wrong
On the cheap side, you can get a RB25 turbo, which is just slightly bigger than the 20 and it will look just like stock, remap the ECU and youll be around 190rwkw (at least I was)
Sell the emanage, to cover some of the costs, and enjoy!
he has to be talking about an RB20 dude, why bother upgrading injectors and pump and regulator to get only 170kw. It has to be an old lazy RB20 :)
he has to be talking about an RB20 dude, why bother upgrading injectors and pump and regulator to get only 170kw. It has to be an old lazy RB20 :ninja:
i don't think the rb20 standard turbo can even handle 175 kw and last for more than a week. upgrading injectors and pump wont produce much more power unless you have the air flow to make it, like a bigger turbo. you'd be able to get a little bit out of it with the EMU but not that big of a step for the rb20 on a standard turbo.
looks like its a good base for a turbo upgrade. if your worried about a turbo upgrade getting unwanted attention then a high flow is definantly the go. you've already got the supporting mods to make some good power.
Edited by QWK32
thanks for the suggestions guys. Lol and and dont bag the hyundai. Nothing wrong with korean made cars......lol
as some of you have guessed, the car is an rb20. i like the sound of the new afm and high-flowed turbo. im guessin a z32 afm is legal still??
if you want it to still look stock but go a fair bit harder, pick yourself up a forklift bottom end and chuck all your top end goodies on it.
that and a highflow will get you up around 230 / 250 kws, and still look like a stocker.
bottom ends can be had for around the $100 mark and then find yourself a second hand rb25 highflow from the fs section, and for $1000 you will gain 75 kws.
cheap power really.
    • If you really don't want to touch anything you can try to trigger off the timing loop just to see if it's sparking semi-regularly. Don't trust it for actual timing measurements.
    • Also replace the fuel filter aswell today
    • Hey everyone, I have a r34 GTT s1, im having a problem with my skyline, ive let the car sit in the garage for the last couple of months and havent run it and ive gone to fire her up today and it cranks but doesnt fire, i have been having problems with it previously where it wouldnt start again after driving it around for a bit. It use to start fine on cold start ups but if you drove to the petrol station and fueled it up and went to go start it again, it would just crank and not fire untill you let it rest for a few hours, the car doesn't over heat it sits perfectly in the middle while driving when warmed up. Im thinking this problem has caught up maybe and now it just wont start at all. The car runs on e85, ive checked the e85 seems to be fine. I can hear the fuel priming before you go to start it and checked all my fuses and relays. List of things I replaced today - New battery - New sparkplugs - New Coolant temp sensor I was thinking about testing the CAS but from what ive seen online, if the CAS is cooked, the car will actually start up but then die instantly? as mine just doesn't fire at all. Does anyone have any idea or have encountered the same problems? thanks
    • Modern reg stuff now, they'd have a wide input range which would push through a buck converter, it would need to be able to maintain voltage for cranking conditions (sub 9V at times). Likely runs something like an internal 6V rail, and then further voltage regulators depending on which circuit/area it is feeding. Modern voltage regs, like what I'm starting a new power supply design with at work, will let me run a 5V rail output, and as long as my input is equal to or greater than 5V, I have a 5V output. Except I'm not pushing a 5V rail in our system as I don't need one, we're setting up for a 3.8V rail. Our new design will allow me 6 to 60VDC input, and everything else doesn't care, even when I start pushing a few Amp outputs.   Realistically, the voltage drop off could be caused by a few things though, one could be literally the alternator is dieing, and hence charge power is dropping, which also means on a straight hard pull you're starting to send the battery flat... (Not that likely from a single couple of gear pull if the battery was fully charged). However, having earth issues, like stray earths not connected, or someone having put a ground loop in, will see the ECU appear to end up with lower voltage "input", mainly because the "ground" is no longer equivalent to battery negative. If they're comparing the input voltage using sensory ground for example, and sensor ground is what is in that ground loop, than the sensor output voltage will actually start to be reduced, when compared to battery ground... Yeah, ground wiring design can start to be a bitch... Also voltage going weird from inductive loads not being managed properly is another real bitch... Hence, why I asked above about how everything was wired in. If OP knows, and can post all of the actual connections from the ECU pin out, as well as what wires are joined where in the loom, which grounds from the ECU have ground points and where they are etc. Would help to see if there is a ground issue. The part I'd start with though, is putting a mechanical oil pressure gauge on to confirm the theory. Otherwise the next track day when the threshold is lowered could result in another of @Duncan favourite types of jokes... Knock knocks... Pretty sure this is what @GTSBoy is also self high fiving...  Is all great that we have a decent theory... But they need to prove it before relying on it...
    • When I worked at BlueScope Steel, we had an Ethernet network, with every switch setup with a duplicate switch. Even when looking at all the primary switches, they had duplicate links, there was then also duplicated links between the primary in section A, to the duplicate in section B. So for each location that had networking, there was 8 network links. This was all back around 2007. That setup caused sooooo many issues, as many of those links were fibre. The network guys ran everything with Spanning Tree Protocol. And then we had great joy... The FOC Transceivers were slowly dieing, but in an intermittent way. And a lot of the time as they started to die, they'd drop offline for about 30 seconds... Spanning Tree Protocol was requiring 45 seconds to "rewire" the network... And by the time it was mostly finished, it had to start again as the transceiver was back online... Queue entire production network being constantly spammed with the spanning tree protocol messages...   My god I do NOT miss working in huge environments like that!
