4drftn Posted September 28, 2007 Share Posted September 28, 2007 hi, i might be needing to replace my coil packs and would like to get a set that will perform and last... iv noticed that there are the JJR coil packs (which are nicely priced under $400) that iv read and claim to perform as well as splitfire coil packs which people have used for a long time ($500), will the OEM coil packs perform as well as these other two? would like your feedback or any info on these coil packs or any prefered or recommended brands... cheers 4drftn Link to comment https://www.sau.com.au/forums/topic/187108-jjr-coil-packs-vs-oem-vs-splitfire-vs-other/ Share on other sites More sharing options...
limpus Posted September 28, 2007 Share Posted September 28, 2007 (edited) I recently needed new coilpacks for my car...contemplated getting splitfires but went with the JJR ones instead as they were slightly cheaper...i can't compare them to splitfires as i've never used them but the JJR ones do work ok...they would have to i guess as they are newer than the standard 15-17 year old ones i had...not sure how long they'll last though...for now...its all good...one annoying thing with the JJR ones though is that Just Jap has stuck an annoying brand and details sticker on each of them which is a bit of a pain to remove...regardless...if anyone has any concrete results for the JJR coilpacks it would be nice to see...cheers... Edited September 28, 2007 by limpus Link to comment https://www.sau.com.au/forums/topic/187108-jjr-coil-packs-vs-oem-vs-splitfire-vs-other/#findComment-3378680 Share on other sites More sharing options...
Oblivion Posted September 28, 2007 Share Posted September 28, 2007 amen to this topic...i would like to know too as i need to get some coil packs. Link to comment https://www.sau.com.au/forums/topic/187108-jjr-coil-packs-vs-oem-vs-splitfire-vs-other/#findComment-3378828 Share on other sites More sharing options...
GTAAAH Posted September 28, 2007 Share Posted September 28, 2007 +1 for this, i'm just curious to find out if the jjr's are good for relatively high powered applications i.e. 400kw'ish i am interested in buying some but would like to see how they perform first... don't know if adequate spark delivery is much of an issue on rb's once u get high power figures Link to comment https://www.sau.com.au/forums/topic/187108-jjr-coil-packs-vs-oem-vs-splitfire-vs-other/#findComment-3378847 Share on other sites More sharing options...
STATUS Posted September 28, 2007 Share Posted September 28, 2007 STD are the best performers but are drug money to buy new, the split fires and superspark and JJR ones are great cheap replacements. Link to comment https://www.sau.com.au/forums/topic/187108-jjr-coil-packs-vs-oem-vs-splitfire-vs-other/#findComment-3379080 Share on other sites More sharing options...
sewid Posted September 28, 2007 Share Posted September 28, 2007 I'd pick the JJR ones over the Splitfires for the local warranty. Unless you're buying splitfires locally I guess but they're going to be over $500. Link to comment https://www.sau.com.au/forums/topic/187108-jjr-coil-packs-vs-oem-vs-splitfire-vs-other/#findComment-3379094 Share on other sites More sharing options...
R31Nismoid Posted September 28, 2007 Share Posted September 28, 2007 I ran my old factory RB25 coils to 369rwkw. So stock coils (in good condition) are fine, and many cars have made bigger power than me. I recently just installed RB26 Splitfires for my RB26 setup, only reason is OEM coils are $$$. JJR ones havent been around anywhere near as long as Splitfires (and other coils like FET), so IMO at this stage its hard to tell on durability under extended periods/conditions. Its something that i would take into account when looking for parts as cars with Splitfires have been running for a number of years, JJR ones, lucky if its a few months i think they've been around for? And no, im not in any way saying the JJR product is garbage. Unless someone knows what re-branded item the JJR ones stem from? Which would provide more info Or are they made by JJR themselves? Link to comment https://www.sau.com.au/forums/topic/187108-jjr-coil-packs-vs-oem-vs-splitfire-vs-other/#findComment-3379277 Share on other sites More sharing options...
PM-R33 Posted September 28, 2007 Share Posted September 28, 2007 I ran my old factory RB25 coils to 369rwkw. So stock coils (in good condition) are fine, and many cars have made bigger power than me.I recently just installed RB26 Splitfires for my RB26 setup, only reason is OEM coils are $$$. JJR ones havent been around anywhere near as long as Splitfires (and other coils like FET), so IMO at this stage its hard to tell on durability under extended periods/conditions. Its something that i would take into account when looking for parts as cars with Splitfires have been running for a number of years, JJR ones, lucky if its a few months i think they've been around for? And no, im not in any way saying the JJR product is garbage. Unless someone knows what re-branded item the JJR ones stem from? Which would provide more info Or are they made by JJR themselves? Completely agreed. For the extra $100 or so dollars ($510 from Slide or nengun), splitfires have been tried by thousands and you know they can make the power and last. The JJR ones may be just as good or even better, however until they have been tested, i know what i would go for. Link to comment https://www.sau.com.au/forums/topic/187108-jjr-coil-packs-vs-oem-vs-splitfire-vs-other/#findComment-3379320 Share on other sites More sharing options...
32vspecII Posted September 28, 2007 Share Posted September 28, 2007 Link to comment https://www.sau.com.au/forums/topic/187108-jjr-coil-packs-vs-oem-vs-splitfire-vs-other/#findComment-3379336 Share on other sites More sharing options...
mad082 Posted September 29, 2007 Share Posted September 29, 2007 any new coils, be they jjr or splitfires, are going to be better than old ones that are arcing out. the jjr ones are probably ones that they have had made copying splitfires. unless you are chasing big horsepower i'd say they would be fine. if you are only running 250kw or below they would be more than ample if your stock ones aren't up to the job. Link to comment https://www.sau.com.au/forums/topic/187108-jjr-coil-packs-vs-oem-vs-splitfire-vs-other/#findComment-3379912 Share on other sites More sharing options...
NYTSKY Posted September 29, 2007 Share Posted September 29, 2007 JJR ones are made in china.But then again some performance products from china these days have proven to be good upgrades. Link to comment https://www.sau.com.au/forums/topic/187108-jjr-coil-packs-vs-oem-vs-splitfire-vs-other/#findComment-3379947 Share on other sites More sharing options...
mad082 Posted September 29, 2007 Share Posted September 29, 2007 yeah, chinese stuff isn't that bad these days (depending). in the bike industry a very large portion of stuff comes from china, most of it good. it is actually the companies that specify what they want the determine whether it is good or not. if they want it to be cheap it will be crap, but if they are willing to pay a bit more they will get good stuff. it is just that there are a lot of people that are getting the cheapest made stuff they can in order to make maximum profit. which means a lot of people buy stuff, and it breaks, which then makes people think that all chinese made stuff is crap. but now china is starting to get expensive so people are going to india and indonesia and vietnam to get things made. taiwan used to be the cheap crap stuff but now it is where better stuff is made. Link to comment https://www.sau.com.au/forums/topic/187108-jjr-coil-packs-vs-oem-vs-splitfire-vs-other/#findComment-3379963 Share on other sites More sharing options...
a20089 Posted September 29, 2007 Share Posted September 29, 2007 ... in the bike industry a very large portion of stuff comes from china, most of it good. Don't agree with this statement. All the stuff I've seen from China has been lower quality than the Japanese made stuff. 1/2 the price for sure. And China may make thousands of motorbikes but not that many make it into Australia. Aftermarket gear they close the gap somewhat, but I won't in general buy china made electronics or important components. Link to comment https://www.sau.com.au/forums/topic/187108-jjr-coil-packs-vs-oem-vs-splitfire-vs-other/#findComment-3380339 Share on other sites More sharing options...
r32woohoo Posted September 29, 2007 Share Posted September 29, 2007 I've got set of jjr coils in my car running 16psi My std coils used to misfire a little bit with a 0.65mm gap Opened the gap back to 0.8 with the new ones and no more misfire Picked up a little off boost power too, from the seat of the pants dyno And with a 1 year warranty they're not bad for the price Link to comment https://www.sau.com.au/forums/topic/187108-jjr-coil-packs-vs-oem-vs-splitfire-vs-other/#findComment-3380349 Share on other sites More sharing options...
tridentt150v Posted September 29, 2007 Share Posted September 29, 2007 Very hard to tell just where parts are made these days!!! Just cos' it has Nike written all over it----------doesn't mean a thing. You can get parts from USA, Phillipines, Taiwan, China, Korea, Japan Thailand and it could have HKS, Blitz, Chev, Holden, Nissan, Toyota, NEC, LG..........you name it on the label. The parent company controls the quality [or attempts to], but that doesn't mean that other manufacturers can't do the same. Link to comment https://www.sau.com.au/forums/topic/187108-jjr-coil-packs-vs-oem-vs-splitfire-vs-other/#findComment-3380366 Share on other sites More sharing options...
zebra Posted September 29, 2007 Share Posted September 29, 2007 This thread will be a good read. Im thinking of going with these JJR coils when I go back to coil on plug. unless I just replace the commodore coils with MSD ones......seriously thinking of going the JJR option though. Link to comment https://www.sau.com.au/forums/topic/187108-jjr-coil-packs-vs-oem-vs-splitfire-vs-other/#findComment-3380499 Share on other sites More sharing options...
funkymonkey Posted September 29, 2007 Share Posted September 29, 2007 had one of the guys who drops into the workshop use the JJR's and claim that he could run plugs gapped at 1.1 on em like they were 0.8's... that's something standard's can't do, and mean that they do pack a bit of a wallop. they're starting to sound like a real good alternative/performance upgrade. Link to comment https://www.sau.com.au/forums/topic/187108-jjr-coil-packs-vs-oem-vs-splitfire-vs-other/#findComment-3380565 Share on other sites More sharing options...
Bumblebee Posted September 29, 2007 Share Posted September 29, 2007 i havent gapped my plugs to .8... stock coils.. lots of boost and no spark problems Link to comment https://www.sau.com.au/forums/topic/187108-jjr-coil-packs-vs-oem-vs-splitfire-vs-other/#findComment-3380588 Share on other sites More sharing options...
4drftn Posted September 30, 2007 Author Share Posted September 30, 2007 i guess we might have to wait for a magazine to do a test or something to really know how they perform against each other, as said above some people are a bit iffy when it comes to chinese products but also as said above some of the chinese performance parts are proven to be a good option being a direct replacement of performance upgrade... does anyone know what the OEM coil packs are priced at??? Link to comment https://www.sau.com.au/forums/topic/187108-jjr-coil-packs-vs-oem-vs-splitfire-vs-other/#findComment-3381558 Share on other sites More sharing options...
benm Posted September 30, 2007 Share Posted September 30, 2007 Give it another year with some decent power and km's to determine if the JJR's can last, but for $100 difference mite as well just go the Splitfires. Link to comment https://www.sau.com.au/forums/topic/187108-jjr-coil-packs-vs-oem-vs-splitfire-vs-other/#findComment-3381641 Share on other sites More sharing options...
