One even has to jump through hoops to get warranty approval on Splitfires :D
I'm sure you're right but like I said - 5 years of supersprinting on Splitfires never produced a problem... One lap on YJ's killed a coil pack!
I always believed that if a customer is dissatisfied with a product because it misperforms he should be entitled to a refund, no matter what your terms of warranty might be.
Unfortunately we cannot let customers dictate terms of warranty. No business does and never would.
We have 2 years warranty on these coils. Are you saying that a customer can make it a 3, 4, 5 or even a 10 year warranty, no matter what the terms of warranty might be?
It simply doesnt work like that.
In offering a 2 year warranty, I have to be sure that, if there is an issue, that the faulty one(s) are isolated from the rest as all 6 coils would not fail at the same time.
Otherwise anyone could simply send me back a full set at say 22 months after purchasing and scam a new set of replacements from me.
And repeat this cycle so they never have to buy coils ever again. Im sure you understand this.
I cannot make up different terms of warranty just for you now can I? That would not be fair on my customers or myself.
Also, we managed to test your coils on one my mates R34 GTTs and couldnt find anything wrong with them. Im not sure why or where these coils mis-performed for you?
Whats done is done though and I dont want o2 to be bitter with me. I will refund o2 for the coils out of my own pocket and will give these to my mate with the R34 as he was totally stoked with them.
Thnx.
Odd thing I noticed on the box of yellow jackets I received today "6 month warranty". So it's actually 2 years? *bit confused*
... If it IS two years then I feel a hell of a lot more comfortable - got a bit worried at the warranty mentioned on the packaging ....
Yep, its 2 years. We are just running out the last of our old packaging. :/
does anyone see a problem with using 2 different types of coilpacks? I had a set of splits in my rig and one of the spark plugs came loose and melted a coilpack and the wiring too, wirings been fixed and because i couldnt find a place that sells splits individually so i went and bought a yellowjacket.
They all theoretically do the same thing right?
there is a trader on nissansivia.com selling nissan OEM coilpacks for $105 a piece
for a stock or even mildly modified application, i'd happily pay for a set of OEM coilpacks over splitfires or yellow jackets
/quote]
When one of my YJ's failed and I was waiting for a replacement under warranty, I put in an OEM from the set I had taken out . It worked just fine.
Just wanted to say big thanks to performance wise, purchase my item via ebay on Wednesday and needed item by Friday. Performance wise went out of there way to delivery and it arrive on time! any whos i ordered these as my standard coil packs who seemed fine gave me the Code 21, common problem of R34 GTT.
Anywhos, fitted these item and error code vanished! TCS,SLIP, Engine light all vanished.
Review: Performance: Car seems a lot smoother and also feels a more powerful likes its noticeable!
Thanks!!
p.s if you guys wanna buy these exc items. buy it directly from their online store and not ebay.. u save $10 :) i of course didn't realize this until after i bought it via ebay ==
Good to hear! I hate driving and seeing those f**king lights come on!!
Will be fitting mine tomorrow :)
Thanks!!
Glad it worked out for ya mate, as said above it really sucks having those lights!!
True galois it's sucks ! Thanks for all ya help bro.
Shell: yeah mate the lights are f*kd but when u fit da Yk coils it's awesome and the error lights clear. Smoother revs more power increase. Very nice
Edited by shorty_01
Just a technical bit of info on that note, I'm no coilpack expert in case anyone wants to chime in, but they won't as such give you a power increase...only return to you what was lost while you were using worn out coilpacks :D
+1. Despite what the advertisements say :D.
As was said in birds post, hence the "+1". If your coilpacks are fine buying yellow jackets/splitfires won't be helping much. It's a pretty pointless semantic discrepancy anyways, point is that it can only return lost power, which means there may or may not be a power gain.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
