Nova Possibly Shutting Down?
Hey there Mate , I just got my local guy to install it Waterhouse Performance, Penrith (specialise Nissan/Datsun and other performance cars) , you can do it yourself if you like , AMS has instructions on their website. Cheers Pac
It's (the TPS) buzzing? Or something else is buzzing in response? Remove the IACV from the plenum. Block the hole into the plenum with your hand. Get someone to start the car. Let some air is. Do the revs flare up? This is checking that the path into the plenum is clean. After that, is the air hose leading to the IACV fuly clear? After that, either you didn't clean it thoroughly enough to allow the valve to move, or it is broken.
Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
