  • Replies 705
Posted Images
short video of today at QR, just shows the car really no flying laps.
i hope to get good video next friday!!
russ
and if you havent seen it before ignition vid of the car after dutton http://www.hioctaneracing.com.au/video.php
the engine is coming out in the morning.
i will have pics of gt block and tomei 2.6 crank,new turbo's , pulley kit etc tomorrow and engine build pics and will post them up , car needs to be running again monday!!
russ
yeah the r33 will be going!! but not until we finish it and run it! not sure when that will be though because we make take it's gear box to japan as spare!
the new project at christmas is this
will be recieving around christmas and post full build details of this car as we go, it will be seem welded , full cage, super light weight, lexan all round, carbon panels , pedal box dry sump etc . etc
cant wait russ so r33 must go to help fund it.
Edited by giant
bloody hell Giant, thats one impressive build up. Hope the pockets are deep when it comes to that Nur 34!!
by the way, which USS auction did you go to to see that 34? Did you actually win the bidding on it and how much was the final bid price? Just curious mate! :worship::(
thanks duncan!
well engine was out this morning, new engine should be ready around lunch time tomorrow to go in, had to get new dump pipes freighted today as the old one's were cracked !!
taking pics so will post em soon.
russ
thanks duncan!
russ
i suppose your selective to those you answer. I may not have a record breaking skyline but id appreciate a response if thats okay with you...
i watched the dutton rally yesterday on fox sports. pitty about the "top end noise" hope the dammage wasnt to bad. also what bit broke in the transmission to lose 5th?
(i bought a ppg and while im inspecting it id like to replace any dodgy factory bits that could give trouble down the road.)
cheeres dave
c'mon mate, back up a bit. I wouldn't necessarily want to share how much my car cost either. but apart from that he may just have skipped the question. does it really matter which auction it was from or how much it cost anyway? I don't think owning a kick arse GTR has anything to do with attitude. in fact yours may be improved if you did own a record breaking GTR as it's not too flash at the moment.
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
