what i want to know is what the hell is: "It's got good rotation"... hmm is it a helicopter? or does it do great 360s at every corner entrance. I'm sure my car has too much rotation.
  • Replies 705
Posted Images
haha - in that case my car has god rotation too - done its fair share of 180s and 360s :w00t:
cya guys! off in the morning, hopefully will be able to get online and tell ya how its going and maybe some pics while there!
thanks cam hope to catch up with ya soon.
fingers crossed all will be good! i know my liver is ready to go and my tonsils are gone for faster beer delivery! :rofl::rofl:
thanks again for the support!
russ
Edited by giant
russ
all the best guys...good luck
not much update. Got to tokyo last night. got to my hotel. realised it's kick ass. had a shower, walked up to my favourite ramen place in roppongi, had some shio ramen, tamago and gyoza and a nice frosty sapporo beer. strolled back to the hotel and practically passed out in bed for a solid 9 hr sleep. just about to head out for the day. :worship: some shopping to do.
Hey all Nismo festival today was awsome the new gtr is an awsome machine and the new GTR race car is pure sex on wheels the boys pick the car up tommorrow and we are all heading to tskuba and they have organized a dyno session for tuesday to check all is good.And then hopefully hand some japanese their ass's on thursday.Will upload a few pics from the nismo fetival and Tskuba when i get a chance.
If I was a betting man, Id guess he's saying it has good turn-in. Either that or he's saying it has good acceleration/revs easily. With the power it has, and the fact it looked ordinary on the track through the corners Id say he was refering to the engine revving easily more then its handling.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
