  • Replies 705
Posted Images
Also watching intensely... that will give me a few months to get the GTR up to pace.
Will a CAMs L2S licence be sufficient? Or even needed? I'm debating whether to renew mine.
Yeah L2S license will be the requirement.
What i found em :-)
They were all homeless and stuff so i give em a good home.
LOL might even bolt a set onto the porsche and take her for a run....just as soon as the clouds disapear that is.
and there is this old shit heap needing a set too
well the r34 is here!! so stripping it down wont be too far away!
if anyone knows some one that needs some r34 bits let me know! apparently it has a tv tuner for the MFD, a good stereo with amp in the boot, all the brakes will go, seats, etc etc will put em up in the forsale section,
but the engine and gearbox i want to try and sell while it's still in the car before we strip it, so whoever buys it knows the state of it!
BTW the r34 i was originally getting from japan , has never eventuated(long story) so this one has been locally sourcedit will be a shame to strip out a fully complied registered r34!!! :P oh well you get that.
pics to come over the weekend hopefully.
another one bites the dust - at least its to one of the best causes possible!
the spec's for the car so far rare, (it will be purely timeattack & sprints, with a sports sedan lod book)
hope to have it done by may! (i hope)
(nearly all this stuff i already have waiting for it)
engine 3 ltr
lovely head work! :P larger valves & inserts etc
hi lift cams around the 280 mark
dry sump
hypertune manifold
not sure turbo setup yet but external gates
electronics
autronic ecu
cdi ignition
motec dash
tranny 6 speed sequential holinger
carbon shaft
cusco diffs
suspension ohlins
full ikeya formula arms
stub axle mods
brakes
pedal box
bias adjuster
alcon monobloc v8 supercar brakes front and rear 365/345
fully caged and seam welded body
single seat
carbon doors
lexan glass
carbon boot
carbon bonnet
aero front bar, side skirts and wing (not yet sourced)
hopefully carbon dash
custome made wheels
custom radiator oil cooler system
thats it for now!
hope it all comes off! but will be posting pics with progress.
You know what the scary thing is though? The 32 would most likely scare the pants off a majority of performance car drivers. You're just getting used to the next level of 'scary'... where does it end? :thumbsup:
On second thought... Ignore what I just said, continue building the super fast scary R34! I want to see this monster! :P
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
