I was thinking of doing the same thing.... im sick of the big shiny wanker effect hanging off the front. I got a hybrid model mounted properly and a stock GTR inter cooler sitting in the garage, its black i wanted to put it on coz it was black but wont fit so i was going to paint the current one black. Reduce efficiency? anyone know?
I have been told that chrome parts can hold in more heat.
Have been advised against using chrome sumps and trans pans for that reason.
I would assume that polished parts would do the same.
Most standard radiators are painted black...
Don't know about powder coating, as it is a relatively thick coating.
Perhaps a paint finish would be better...
yeah i would probably go for a quick paint with some matt or satin black. if you powder coat it you may end up with a thick layer through the fins restricting airflow not only through the cooler but to the radiator as well.
ive just used a few layers or spray can black paint to repaint my gtr one its seems fine cant pisck a difference cant say i put a temp prob in before or after though. power coat is pretty thick stuff , when thres a small gap say one or 2 mm on the ute trays i make sometimes if they put the power on thick enough it will bridge the gap? if that helps
the very best way to do it would be to get it annodized black. that way airflow is not restricted at all as you are actually dying the alloy.
Thanks for all answers,I will check if it is possible to get it annodized , or as some said just paint it black
For best thermal conductivity, heat transfer rate, dissipation, (imho) ;
1. Bare metal.
2. Anodised.
3. Etch primed or painted, single coat.
Dunno if one colour is more or less efficient than another in this case? Black absorber/white reflector?
After this I imagine you would be heading towards significant insulation qualitys, ie., powdercoating..........................my 2c.
Cheers GW :)
a lot of places that do chrome plating do it. otherwise you can do it yourself but it can be messy, and dangerous. but it would conduct heat exactly the same as bare metal since you are actually just dying the metal. you aren't putting another layer over the top. you are changing the colour of the alloy.
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
