I was thinking of doing the same thing.... im sick of the big shiny wanker effect hanging off the front. I got a hybrid model mounted properly and a stock GTR inter cooler sitting in the garage, its black i wanted to put it on coz it was black but wont fit so i was going to paint the current one black. Reduce efficiency? anyone know?
I have been told that chrome parts can hold in more heat.
Have been advised against using chrome sumps and trans pans for that reason.
I would assume that polished parts would do the same.
Most standard radiators are painted black...
Don't know about powder coating, as it is a relatively thick coating.
Perhaps a paint finish would be better...
yeah i would probably go for a quick paint with some matt or satin black. if you powder coat it you may end up with a thick layer through the fins restricting airflow not only through the cooler but to the radiator as well.
ive just used a few layers or spray can black paint to repaint my gtr one its seems fine cant pisck a difference cant say i put a temp prob in before or after though. power coat is pretty thick stuff , when thres a small gap say one or 2 mm on the ute trays i make sometimes if they put the power on thick enough it will bridge the gap? if that helps
the very best way to do it would be to get it annodized black. that way airflow is not restricted at all as you are actually dying the alloy.
Thanks for all answers,I will check if it is possible to get it annodized , or as some said just paint it black
For best thermal conductivity, heat transfer rate, dissipation, (imho) ;
1. Bare metal.
2. Anodised.
3. Etch primed or painted, single coat.
Dunno if one colour is more or less efficient than another in this case? Black absorber/white reflector?
After this I imagine you would be heading towards significant insulation qualitys, ie., powdercoating..........................my 2c.
Cheers GW :)
a lot of places that do chrome plating do it. otherwise you can do it yourself but it can be messy, and dangerous. but it would conduct heat exactly the same as bare metal since you are actually just dying the metal. you aren't putting another layer over the top. you are changing the colour of the alloy.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
