Hey guys, i recently converted my car from auto to manual, thus not needing an auto tranny cooler anymore, its just sitting there doing nothing now!
whats the safest way to remove it all, and will i need to block of the lines on the radiator????, i was thinking of just removing the cooler, and the two hoses connected to it, and tracing them back and removing them aswell.....it seems as though theres two hose that are going into the radiator coming from the tranny cooler?
Yes Its safe to remove all the lines.
Just make sure you drain all the trans fluid out of the radiator other wise you will more than likely end up bent around a telegraph pole as the fluid drains out while driving. and plug the ends that go into / out the radiator
Better Still would be to buy a manual radiator.
