Excellent news. Well done PRSC for finally getting something firm happening.
Also a massive 2 thumbs up to LMRE for their efforts in bringing this to everyones attention with so much commitment. If I knew who you all were I'd be submitting you for Australia Day awards for services to community, road safety, motorsport and heritage.
I'd throw my hat in to help as well but unfortunately I'm a bit broken in the back dept and can't work at all, but I'm with you in spirit. Well done to those who can help too for offering their time.
If anyone can remember the history of Lakeside, it was volunteers that made it happen.
Thanks GTRGeoff, I'll pass on the well wishes to the LMRE members. I understand what you're saying. I'm the proud parent of a herniated disk. But don't miss out because of that, I'm sure we'll need vital experienced support crew to keep the reconstruction machine running, maybe you can help in that area?
Edited by lakesideguy
    • Thanks Mate, I did know you could do that but i know there is a pump out there that you can bolt on and it all lines up. I was told about it and then forgot the model, I figure if i am pulling it apart i will just put a new one on
    • You can also remove the veins from the HICAS portion of your existing pump.
    • Trying to swap the rear subframe on my R34 and can't remove the L-shaped stay brackets between the front subframe mounts and the sill/chassis. I'm in the UK so rust is a problem. I've used loads of WD40 and then Tunap 103 for days beforehand. I backed off the bolts forward a bit, backward a bit repeatedly for ages to try and avoid snapping. They have all moved a few full turns. The one I've spent most time on has come loose and I can turn with fingers, and it will pull down and push up 2-3mm. But it won't come out. I can tighten it back up and loosen it off again repeatedly but it still won't come out. I assumed there's a captive nut inside but if that's broken loose then I can't understand why I can always tighten the bolt back up - I'd expect it to just spin both ways. Any ideas what's happening here? I can't visualise what's inside there to cause this.
    • Cheers, yeah it was recently imported, is the actual Nissan not an Infiniti so will have to do some chasing around for parts.    Any ideas if the side skirts from a Q50 would fit on the 400r?
    • I remember reading that there’s a power steering pump from a modern car—possibly a Mazda—that bolts directly onto an RB engine and lines up perfectly, making it a great option for HICAS removal. Unfortunately, I’ve forgotten which model it came from. Does anyone know what vehicle this pump is from? Any help would be appreciated.
