Hi guys
Last week the power steering on my car decided to stop working, steering became quite heavy, so I went ahead and checked the usual suspects.....
- speedo is working
- belts are fine
- fluid is fine
So I thought "the pump", went to my local wreckers and got myself a new pump, installed that and to my surprise it didnt fix the problem, went back to the wreckers to ask for another pump, got that, went back home installed it.....nothing AGAIN :) .
So now Im thinking what are the chances that both these pumps were dead? I believe the problem may just be somewhere else, but dont know where to start looking now.
So if you guys can give me any ideas, that would be sweet, this is doing my head in :)
Cheers
Ric
Edited by Richo
https://www.sau.com.au/forums/topic/187267-power-steering/
Try searching under hicas problems, but if that fails here's my suggestion for the pump itself.
open up the pump and check the magnets inside, if you see any sign of wear inside the pump, then there is contamination somewhere in the entire power steering pump system. By changing pumps only you're actually causing the shavings to cycle through each pump you put on the car.
You could have shavings, cycling from the steering rack, through to the pump. Whilst you are there, your pump may have some type of pressure switch setup, and it may not be working properly. From what I remember when i checked mine on an R33 and R34 pump, there was a spring and ball bearing type setup that you can get to, to see if that area is releasing freely.
https://www.sau.com.au/forums/topic/187267-power-steering/#findComment-3381289
Thanks guys, ill have a look at the PRV (if I can find the thing) :( and the fuses and see how i go
FYI.. I looked under the car and the right hand side steering rack boot was completely destroyed, I had noticed that it was split a few months back, but now its totally open and perhaps letting alot of crap in to the system. Any way of flushing and cleaning the PS system , or is it a matter of getting a whole new rack???
Cheers
Ric
https://www.sau.com.au/forums/topic/187267-power-steering/#findComment-3382751
I found a blown fuse on the dash board, at least we are getting somewhere here. :(
Now does anybody know what this fuse controls? I just dont have access to a new fuse now, being public holiday and all.
Cross fingers thats the answer though.
Cheers
Ric
https://www.sau.com.au/forums/topic/187267-power-steering/#findComment-3382931
Cheers
Ric
From memory it was a 15 or 20A fuse that blew in my bro-in-laws car. Looks very familiar. I noticed you have a 10A and 20A in the spare fuse holders. You may be able to try a 10A if it is a 15A that blew. At least to get you going until you get the correct one.
Cheers
https://www.sau.com.au/forums/topic/187267-power-steering/#findComment-3382970
edit:
Ben mate, you were right on the money, the blown fuse on the loction shown on the pics is a 10A....now Im not sure whether this fuse is purely for the PS but I put on one of the spare 10A's on there and voila!! PS is sweet now!
Hope this helps any one in the future, check your fuses and go from there.
Thanks again Ben, and to the others for the suggestions :D
Ric
Edited by Richo
https://www.sau.com.au/forums/topic/187267-power-steering/#findComment-3383256
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
    • I definitely agree with you there - I never click on content for cars I would never ever be able to get or compete with/against/be seen next to. Seeing a MX5 compete with a FD RX7 will make people upset though, for sure. Even in 2.5L Turbo form which is pretty grass roots. (or at least as grass roots as classic cars can be) Yes we're all classic car owners now.
    • Wonder what the cause is, but here's hoping it's nothing too serious.
