Hi guys
Last week the power steering on my car decided to stop working, steering became quite heavy, so I went ahead and checked the usual suspects.....
- speedo is working
- belts are fine
- fluid is fine
So I thought "the pump", went to my local wreckers and got myself a new pump, installed that and to my surprise it didnt fix the problem, went back to the wreckers to ask for another pump, got that, went back home installed it.....nothing AGAIN :) .
So now Im thinking what are the chances that both these pumps were dead? I believe the problem may just be somewhere else, but dont know where to start looking now.
So if you guys can give me any ideas, that would be sweet, this is doing my head in :)
Cheers
Ric
Edited by Richo
https://www.sau.com.au/forums/topic/187267-power-steering/
Try searching under hicas problems, but if that fails here's my suggestion for the pump itself.
open up the pump and check the magnets inside, if you see any sign of wear inside the pump, then there is contamination somewhere in the entire power steering pump system. By changing pumps only you're actually causing the shavings to cycle through each pump you put on the car.
You could have shavings, cycling from the steering rack, through to the pump. Whilst you are there, your pump may have some type of pressure switch setup, and it may not be working properly. From what I remember when i checked mine on an R33 and R34 pump, there was a spring and ball bearing type setup that you can get to, to see if that area is releasing freely.
https://www.sau.com.au/forums/topic/187267-power-steering/#findComment-3381289
Thanks guys, ill have a look at the PRV (if I can find the thing) :( and the fuses and see how i go
FYI.. I looked under the car and the right hand side steering rack boot was completely destroyed, I had noticed that it was split a few months back, but now its totally open and perhaps letting alot of crap in to the system. Any way of flushing and cleaning the PS system , or is it a matter of getting a whole new rack???
Cheers
Ric
https://www.sau.com.au/forums/topic/187267-power-steering/#findComment-3382751
I found a blown fuse on the dash board, at least we are getting somewhere here. :(
Now does anybody know what this fuse controls? I just dont have access to a new fuse now, being public holiday and all.
Cross fingers thats the answer though.
Cheers
Ric
https://www.sau.com.au/forums/topic/187267-power-steering/#findComment-3382931
Cheers
Ric
From memory it was a 15 or 20A fuse that blew in my bro-in-laws car. Looks very familiar. I noticed you have a 10A and 20A in the spare fuse holders. You may be able to try a 10A if it is a 15A that blew. At least to get you going until you get the correct one.
Cheers
https://www.sau.com.au/forums/topic/187267-power-steering/#findComment-3382970
edit:
Ben mate, you were right on the money, the blown fuse on the loction shown on the pics is a 10A....now Im not sure whether this fuse is purely for the PS but I put on one of the spare 10A's on there and voila!! PS is sweet now!
Hope this helps any one in the future, check your fuses and go from there.
Thanks again Ben, and to the others for the suggestions :D
Ric
Edited by Richo
https://www.sau.com.au/forums/topic/187267-power-steering/#findComment-3383256
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
