just back from the tuners its like a new car just got a gt3076r installed running 16psi on low boost setting and 21psi on high boost settings. any one tell me what this dyno sheet is telling me. looks like at the top end its letting go. could this be cams?
i have all the supporting mods.
cheers
https://www.sau.com.au/forums/topic/187275-just-got-r33-from-tuners/
PS, i have no idea how or why Cams would give you jumpy power like that.
I really doubt that's what it is, and the power level (250) isn't anything that Cams would have a problem with.
I guess what i'm saying is that Cams could handle 2000rwkws as long as the engine and turbo were up to it.
The only reason you would change Cams is to improve power gains across the rev range etc....
Nothing wrong with standard though if you're punching more air in.
Two distinct dips but not shaky looking graph line.
I'd suspect 1-2 degrees of timing taken out to address knock. A look at your ignition map will soon tell. :)
The over 4000rpm results looks good, but what do you think about things under that engine speed? Looks a bit lazy to come on for you. This spec should be generally similar to The Mafia, and he's pulling 300kW out of 18psi + a much more linear looking curve throughout the range with the assistance of water/meth.
Edited by Dale FZ1
I'd suspect 1-2 degrees of timing taken out to address knock. A look at your ignition map will soon tell. :P
whats your timing degrees tuned at? if you take out 1 - 2 degrees timing, you will get slightly better mid range power but less peak power..
Previous posts by Murat, and the comment about "all supporting mods" indicates he has a PFC.
I'm suggesting it's in the spark mapping ie adjusting one or two specific cells in the map, not the base timing being adjusted by a degree or two :)
Could be wrong but that's where I'd look if there is a concern/query about the shape of the graph
Edited by Dale FZ1
Explain to me how removing timing is going to improve his midrange???
Id really like to know!
It looks like the exhaust housing may be to small If its not retard to much in the topend.
What sort of timing is it running through the top?? and like others have suggested what exhaust housing are you using??
core number is 700382-5012
compressor housing is .60A/R
turbine housing is .82A/R internal wastegate
if that helps is there any one i can take the car too give me a hand with the problem?
money is no problem.
dude, thats the same turbo as me. (GT3037) I make 15psi by 3900rpm in second gear.
The bigger rear must give it a bit more lag hey?
Also, can you list your supporting mods?
I make just over 300rwkw at 18psi on this turbo.
Engine management - PFC
Boost ran - 18psi
Turbo - Garrett GT3076r
Nismo 740cc injectors
Bosch 040 pump
Gready EBC Profec II
Z32 80mm Air Flow Meter
Hybrid Intercooler
3inch Exhaust turbo back
Splitfire Coil Packs
Stock Internals
no head work
Fuel pump
its not that bad i get about 15psi by 3800rpm its depends on the engine load at the time 5th gear its full boost by 3500
thats strange, as I have almost the same setup, but with a smaller turbo rear.
That wavey line looks dodgey. Are the AFR's staying safe while it is doing that? Is the fuel pump healthy? You'll need to test your pressures.
AFR are safe its is running rich because after about an hour of driving the back bumper has a light black color, fuel pump was installed about 3 months ago brand new, what i will check is the cat see if it is choking and do a pressure test, i know i should be getting abit more becuase i have read your 300kw advantage this is what i have built my car from. so im abit shocked.
anything else you reckon i can check out ?
i have notice one more thing with the car the idle is very high sits at about 900 to 1000 rpm, i tried to reset it to a lower figure but it still sits up at 900 to 1000 rpm could this be a connected problem?
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
