Hi everyone, past couple of weeks i've been reading the forums about R34's, namely GT-T, to learn as much possible before buying one.
On the weekend i finally bought one. Now just a couple of questions hopefully you guys can answer me:
1. Is there any way to brighten the dash lights (namely the centre gauge) as its a bit dim. Or is there anyway to change the lights?
2. When you press the central locking button on the drivers side door, does it also lock the drivers door (as mine only locks the passenger door)?
3. When you pull the lever on the drivers side seat for people to get into the back seat, does the seat move forward? The passenger's side works fine?
4. There's a switch on the drivers side which has a picture of headlights (i think) that has 4 settings. What is this for?
5. There's also another switch near the gears (centre console) which has a picture of a steering wheel. Whats this for?
Sorry for question 4 and 5...they are still trying to find the user manual for me.
The reason for 2 and 3 is because i'm not too sure if its like that/if it was manufactured like that or if its an actual fault.
BTW, the car is stock and auto. Only has the front lip which has 'skyline' written on it.
Cheers
https://www.sau.com.au/forums/topic/187291-r34-noobie/
Congratz on the purchase.
1. there should be a dail near the steering wheel... the dimmer was needed for compliance, so it wouldnt look to flush with the car
2.thats correct..only the passenger should lock. when you manually lock the driver side, that will lock all doors
3.i have a 4dr so im not sure, but that should be right
4. that will be the XENON headlight adjustment. if you select the setting one by one, the low beam light moves up or down and adjusts accordingly. thats why they had to take the xenons out from compliance and put normal bulbs in. cause we have to manually adjust the angle of the low beam. i think european cars like BMW have it auto adjustment . it is just so you wont blind oncoming traffic when your going up/down a hill
5.well when your on tiptronic mode, you push the switch and you should see a display on your cluster of a steering wheel that means you can change gears on the steering wheel...which has a + and - so you can gear up/down.
https://www.sau.com.au/forums/topic/187291-r34-noobie/#findComment-3380965
Thanks for the quick replies!
E_Lu-SHuN: Where is this dial you are talking about? I can't seem to find that.
Just regards to number 2: I've actually got a central locking buton on the drivers door. If i push it will lock all doors except for the drivers door. However if i manually lock the door (as in push the locking mechanism on the door), then both doors will lock.
Can any other R34 coupe owners answer the drivers seat question?
Thanks in advanced
https://www.sau.com.au/forums/topic/187291-r34-noobie/#findComment-3381581
The car is about 10 yrs old. All the lights will be crappy in most cars. Just change them if it's bad at night.
If you use the button to lock, it only locks the passenger side door. This was how they designed it from factory.
Passenger side seat will slide forwards when lifting the lever but not the drivers side. This is the way it was designed, also for other manufacturers.
The adjusters are for your xenons.
I don't know of this wheel dial next to shifter.
https://www.sau.com.au/forums/topic/187291-r34-noobie/#findComment-3383684
no dimmer switch on mine either. and yes i get a weird hdd type noise too, not only when its cold though. just randomly all the frickin time. stereo drowns it out easily enough but would like to know what the hell it is makin that noise coz im sure it aint supposed to be makin a noise like that. :)
and to the orignal post with the dash lights being dim. 666DAN sells led replacement kits for like $20 + delivery. http://www.skylinesaustralia.com/forums/t158385.html many colours to chose from I'll be getting a set of the bright white ones when he's back in action next week.
also would like to get the xenons back in my car when i have money again (just put my car in for 100,000km service = $1500 goone.)
anyways congrats on the new car :(
https://www.sau.com.au/forums/topic/187291-r34-noobie/#findComment-3384902
mine didnt come with a dimmer switch either....i spent 2 whole days looking for that f**ker....
do you get a noise like an old hard drive booting up from behind the dash when its cold?...or does anybody?...
Is the noise from behind the main dash, or behind the triple gauge cluster?
https://www.sau.com.au/forums/topic/187291-r34-noobie/#findComment-3384927
Thanks for all the replies guys, really appreciate it. Now i have 'peace of mind' as i thought the seat and central locking thing was a fault with the car.
Just 2 quickies...
1. The hazard light button, is that meant to be illuminated when you turn on the lights?
2. The centre console with the gear stick, are the park, reverse, drive etc meant to light up?
LOL, most of my questions looks like they are regarding lights, whether they light up or not.
Cheers
https://www.sau.com.au/forums/topic/187291-r34-noobie/#findComment-3385384
Just 2 quickies...
Cheers
1. im not too sure, but i dont think soo
2. Yes it is supposed to be lit up. might be a blown bulb if its not lighting up.
https://www.sau.com.au/forums/topic/187291-r34-noobie/#findComment-3386183
the noise from behind your dash could be the climate controll fan direction motors moving into place.
makes the noise even when the climate control is off. i just got a call from the mechanics and i get the car back today instead of friday so ill have a look at it thisarvo.
https://www.sau.com.au/forums/topic/187291-r34-noobie/#findComment-3386891
car hasnt made the noise since i got it back from the 100,000k service. if it makes it again ill just turn the stereo up anyways :)
Hows the car goin anyways atomnaya? sorry for hijackin the thread.
https://www.sau.com.au/forums/topic/187291-r34-noobie/#findComment-3397341
Car has been excellent, although i've been driving it like a granny....wife is usually in the car with me and she would sell the car straight away if I drove it hard :(
Just got installed the immobiliser and alarm so i do have that peace of mind. The first week all i had was the factory central locking, club lock and plenty of prayers to make sure no-one steals my baby.
I'll post up some pics soon
Edited by Atomnaya
https://www.sau.com.au/forums/topic/187291-r34-noobie/#findComment-3398542
  • 1 month later...
Just 2 quickies...
Cheers
Just got my R34 3 weeks ago #2. auto shift lights are not working either. In the mean time u can just see on the main dash what gear ur in (auto's only im sure), but yeh it is a pain in the ass, never got round to seeing if its a fuse or not.. let me kno how u go with it.
Edited by MellowYellow
https://www.sau.com.au/forums/topic/187291-r34-noobie/#findComment-3479876
  • 3 weeks later...
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
    • So my car is finally back from paint! This took an absolutely insane amount of work and should get it's own build thread - but I didn't build it. It was completed by Troy @ https://scalekustoms.com.au/ I originally bought the AOSHIMA URAS Type R kit while I was in Japan, it's supposed to look like this when assembled: Now, I thought that was cool enough until I opened the box with Dismay, as there's no way I could possibly have completed it. The thing is 1/24 and has details down to the steering wheel horn button, which is a 2mm diameter sticker. I originally wondered if someone could make it at all, as is - But then things got a little carried away. It's worth noting that the model does not have an openable bonne, let alone engine bay, OR an openable boot. - Troy has worked wonders with 3D printer and presumably better eyes than I will ever have. My photos suck, so I will post up some of his in-progress ones he sent to me during the way. Unsuprisingly, he is very detailed. A lot of these are out of order. But he: 1) Made a LS engine and an engine bay appear out of thin air 2) Made the bonnet removable 3) Printed the rims I will buy in the future (or any rim you want) 4) Printed and added the wing that is going on 5) Tinted my back windows as this is what my car has IRL (privacy glass) 6) Added a licence plate. 7) Somehow did the interior 8) 3D Printed my actual seats 9) Made the exhaust under the car connect even though this is likely invisible. 10) Created a boot with my fking battery box, power steering reservoir, subwoofer and toolboxes back there. To say it's insane is an understatement. And I f**ked it all up because when I was re-mounting the wing (it broke in transit) I spilled glue everywhere and ripped paint up and Gregged the rear half of the car. Which about makes sense. Also, this arrived on the same day. Quite the change from: I spent 16 hours per day over the next 3 days pre-christmas putting the interior back together, mounting lip, fixing various bodykit problems with window mouldings, etc. and servicing, rebuilding my 370z brakes to go on the car 'soon', messing with heights to check clearances for new wheels, etc. I also had a foray into mounting wiper-mounted washer jets which was an absolute disaster. The bodyshop has welded (and painted) over the stock jet locations for reasons unknown to everybody (i.e they forgot) I also wanted to wire in the oil pressure sensor on Christmas Eve which was a BAD IDEA. You do not know terror like pulling your ECU apart, pinning in half-fitting pins that aren't the right ones, but trying anyway because it's Christmas eve, putting your ECU back together and having a no-start condition with a fuel pump not priming. Then you undo all your work and the fuel pump still doesn't prime. So after all that terror and horror and pain and tedious disassembly, the issue was the relay in the boot which seems to have died/stuck when I was turning the car off and on about 700 times testing shitty washer jets. I also re-wired the fuel pump power plug which fell apart in my hands. I am very happy I had 3 extra pre-made ones from a few posts/last Christmas's breakdown. https://bluewireautomotive.com/products/10-x-pcm-ecm-ecu-terminals I have put an order for these in, so I can actually add the pins to the ECU properly. The commodore ECU does not have the pins for Oil Pressure via ODB2. However the ECU can support it if you create the pins and wire them in. So for round two, and somehow attempting to route that into the engine bay through my impossible engine bay grommet is a fight for another day. It's 40C in Melbourne tomorrow, I am half tempted to drive the car with the aircon on to deliver presents to my partner's family and see if it helps with the overheating-on-40C-days-in-traffic-with-aircon-on-only issue that the vents were intended to solve. Do I feel lucky?
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
