rebuilding a rb25 lookin at cheaper alternatives then forged rods tryin to do this rebuild on a budget so wondering do rb26 conrods fit on a rb25 crank and will the standard size rod bearings suit?? also r the stroke lengths the same ie. same sized rods etc. any information is greatly apreciated cheers guys
https://www.sau.com.au/forums/topic/187315-do-rb26-conrods-fit-in-rb25/
RB26 is a "stroked" RB25 - both engines have same bore. (Probably RB25 is actually a de-stroked RB26)
RB26 gudgeon pin is higher up the piston - don't know if this indicates that the rods are the same length.
Why not just use standard RB25 rods?
lookin for sumthin stronger as hopefully ill be puttin forged pistons in aswell and ill be running high psi and yes i should put forged rods in but cant really afford it so im tryin to cover the neccesities and doing my best elsewere. im only rebuilding as my cureent engine has got 70 psi in cyclinder 2 due to over a year with 22psi has a hks gasket but standard internals r only good for so much so just lookin at all my options
if i were going to build my engine and was thinking about going on the cheap but keeping it in standard block guise and not going the 3.0l route then i would use the
*rb26 rods *forged pistons *thicker head gasket *clean the head up with reco and port matching done on the inlet and outlet yada.
they use these rods to over 300 rwkw in the gtrs.thats some serious power for a rwd street car.
Doesn't compare to $200 for used RB26 rods. Yes they fit. They bolt straight in, no mods, perfect. The difference in the RB26's is the pistons. The rods are the same length, just thicker and so therefore stronger.
I know a GTR that had standard rods with 440awkw or so and when it went it was a spun bearing. Rods were fine.
cheers for the replys guys everything just helps me in making my mind up. my rb25 was putting out 440 hp on standard internals had a hks 2mm headgasket so tryin to build a v low budget motor which can support that power if not even drop the boost a lil and make sumthing nice and reliable but still fun ;-)
I have a set in my room that will be going into my RB25.They have been fully balanced,honed,small ends replaced complete with new ARP bolts.
Will be enough for my power needs thats for sure.
    • I'm selling my brand new, in the box, never used Hypergear ATR45 - and I had some additions I paid for a few yrs back when I purchased it. Never ended up having the rest of the money to add all the mods at once, so I just ended up slowly selling each part. I originally had it internally gated, with the dump pipe, however I found it was incompatible with what I was going to use it for, so I contacted (I think Ken) from Hypergear, and he and I messaged back and forth & he got me to ship the turbo back, where they modified it & made it externally gated, and gave me the 5 bolt dump pipe attachment for custom welding. (Photos below) This turbo like I said has never touched the inside of an engine bay, it's completely brand new, never used, been sitting in the same box it arrived in, covered in plastic & all. Below are the photos of it: And while the guys at Hypergear were making it in-shop, they sent me some photos of the process: I'm looking at selling this just because I'm in need of the money right now, and don't have plans on modifying the 34 anytime soon - and from reviews & peformance sheets, this turbo had amazing results back when I was researching. The turbo was purchased in 2018 for $1.9k, with the mods I got added on. Looking at the website now, for the same turbo they sell (ATR45SAT), with the current addons it adds up to $1830 for the turbo Current addons included: - Bolted dump adaptor - Ball bearing CHRA - Braided oil feeding line So I'm looking to possibly sell it for around $1800, with shipping included in that 1.8k, It cost me around $120 to ship - so yeah thought I'd throw it out there and see if anyone was interested in purchasing. Cheers!
    • Turn up your speakers https://youtu.be/5_GK5ChNjOs?feature=shared
    • This thing did a 1:20.88 at Winton on the weekend which is f**king rapid.  Well done mate, your driving has really gone up a few notches not much left on the table now! Good luck at WTAC.   https://www.facebook.com/share/r/1MHyZQBqZ2/
    • Are you guys meeting up with the Sydney SAU guys at Lambton Pool Carpark or heading straight in?
