1x Mtx Roadthunder 1x Clarion Apa250 2x Jl Audio 6" Speakers
Item: MTX RTP404 Road Thunder 4x75W Amplifier
Item Condition: Used
Price and Payment Conditions: $150 ono
* Power output: 37.5 watts RMS x 4 (4 ohm load), 75 watts RMS x 4 (2 ohm load), 150 watts RMS x 2 (bridged mono, 4 ohm load)
* Frequency response: 20 Hz-20 kHz
* THD: Less than 1%
* Signal to noise ratio: Greater than 100 dB
* Dimensions: 9.75" W x 2.1" H x 11.5" L
* Regulated PWM Mosfet power supply
* Defeatable 85 Hz 18dB crossover, selectable for low pass/high pass operation
* Smart-Engage™ auto turn-on/turn off for easy integration to head units
* Real-time computerized protection circuitry
* 2 ohm stereo stable
Pictures: 267-053ii.jpg
Item: Clarion APA250 Amplifier
Price and Payment Conditions: $50
Clarion's new APA series amplifiers have the flexibility and customizing options to satisfy even the hard-core tweakers. The performance is more than just skin deep, too, with a built-in low- and high-pass crossover, line or speaker level inputs, Bass Extender boost control, and no-sweat 2-ohm load stability. A high impedance differential input stage makes sure zero noise gets into your system. Beauty meets brawn in a marriage of high-tech fury!
Features
* Built-In Variable Low-Pass or High-Pass Crossover
* 50-250 Hz Crossover Frequency
* Crossover Frequency Multiplier
* Line or Speaker Level Inputs
* 2 Ohms Stereo / 4 Ohms Mono Stable
* Gold-Plated Input and Output Terminals
* Bass Extender 0, 6, 12 dB Boost Control
2-Channel Amp Specifications
* Amplifier Type: 2-channel
* RMS Power @ 4 Ohms: 50W x 2 @ 14.4V
* THD at 4-Ohm RMS Power: 0.1 %
* Bridged RMS Power @ 4 Ohms: 200W x 1 (maximum)
* Speaker Level Inputs: yes
* Preamp Outputs: no
* Built-In Crossovers: HP/LP
* Bass Boost: 0, 6, 12 dB
* Frequency Response: 20-20,000 Hz
* Signal to Noise Ratio: n/a
* Fuse Rating: 25 amps
Pictures: CLAAPA250_1.jpg
Item: JL AUDIO TR600-CXi Coaxials 6"
Website: here
Price and Payment Conditions: $100
Description:
Evolution™ TR 6.0 in. / 150 mm Coaxials
Grilles Included. Perfect fit in many Japanese vehicles.
This speaker system is a perfect fit for many Japanese cars that won't accept a true 6.5-inch speaker without modification. The basket features three and four-hole patterns that match up with all factory mounting locations.
Woofers:
Injection-molded, mica-filled, polypropylene cone body, 1.0 in. / 25 mm voice coil, flat-profile/symmetrical-roll spider, butyl rubber surround.
Tweeters:
0.50 in. / 12 mm textile dome tweeter with integral phase plug, ferrite/ceramic magnet, ferrofluid cooled and damped.
Continuous Power Handling: 50W Continuous
System Efficiency: 90.5 dB @ 1W/1m
System Nominal Impedance: 4 ohms
System Frequency Response: 59 Hz - 22 KHz ± 3 dB
Pictures: 5762.jpg
Contact Details: PM me!
ALL MUST GO THIS WEEK OR GOING ON TO EBAY ! :wavey:
