SOLD
Item:
2003 Ford Falcon BA XR6 Turbo
125,xxx kms
Black
4-speed auto (SSS)
Sedan
Brisbane - southside
Website:
http://www.carsales.com.au/used-cars/priva...8&D=4690128
Item Condition:
Excellent
Reason for Selling:
Mortgage and marriage. :P
Price and Payment Conditions:
$21,900 ONO
No swaps sorry.
Extra Info:
URGENT SALE. MAKE ME AN OFFER.
No accident damage. Always garaged.
I'm the third owner.
First 100,000 km was driven by manager of Simsmetal, mainly interstate/highway kms.
Full service history - serviced at Ford dealers.
In last 10,000 kms has had:
Full 120,000km service.
2 oil changes.
New spark plugs.
New brake pads (EBC Reds).
Bled brake fluid (Motul Factory Line).
Replaced rear diff centre bush at considerable expense.
Comes with following modifications:
Bilstein shocks (only 10,000km old).
King springs (low front, superlow rear).
RDA slotted front rotors.
EBC Red pads.
These items transformed the behaviour of the car, handles and stops so much better than a standard car (or an FPV for that matter) it's not funny, whilst retaining decent ground clearance and comfortable ride.
Custom CAPA Flash Tune at Elite Automotive, Brisbane.
242 rwkW - i.e. approx. 320kW at the engine. Will supply dyno charts.
This is a very safe tune, 12psi tapering to 8.
CAPA box (included) has 4 tunes: factory, 98RON road, 95RON road, 98RON track.
Nizpro valvespring upgrade.
BMC panel filter.
The tune has also uprated the shift speeds in "tiptronic" mode - now changes gears very convincingly and can be made even more aggressive if desired upon retune.
Has only been in a "tuned" state for 10,000km.
Factory options:
Black leather, with red "XR" logos.
Premium sound package with colour display screen and 8" woofer.
Genuine Ford iPod amplified audio input.
"XR" Floormats.
Also has a Nokia handsfree kit installed.
Always run on 98/100 octane fuel.
On stock 17" wheels with OEM Dunlop rubber.
Car was professionally touched up to remove stone chips etc. before I bought it.
Driven mainly in 80-90 km/h zones, light traffic. This car does not spend its time sitting in traffic jams. Runs perfectly, and gets surprising economy especially on the open road, given the amazing performance.
Can produce all receipts for modifications and servicing.
ANY SERIOUS OFFER CONSIDERED. No test pilots.
Pictures:
Contact Details:
John
Enquire on carsales, PM here, or text/SMS to 0407 171 337.
ill take the turbo :D
Haha "For sale, XR6 Turbo with no turbo, rest of car immaculate" :laughing-smiley-014:
Looking for offers over $20K guys.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
