or the box aint compatible with the pfc, i have the older style fc datalogit an d the new and trhe old one has two boxes to cover all the cars.
box 1 does s13, s14, r32 and r33
box two does r34 supra soarer etc....
new version is black old version is white.
and yeah check your com port setings for your usb driver.
ok, well the car is for a R33 and the fc datalogit bos is black. Ill have another play with it tonight and see if i can get it to work. Do i need to change the com ports on the laptop or just swap the usb into different ports?
thanks
thanks
make sure the com port selected in the datalogit is the same as the com port listed for the usb to serial converter in device manager.
I just got my FC-datalogit and was having troubles with an error.
I've got an R33 series 2 GTST and the Black datalogit.
It eventually worked with com port 2 selected. I just chose the lowest com number available.
I just hope it works next time I plug it in :blink:
