I have a heap of R34GTR parts lying around so out they go!!
Exedy twin plate EC $1400
Complete EC Getrag Gearbox/transfer case $4000
Active rear diff and driveshafts $800
Nismo 320km Cluster $500 *SOLD*
Brembo Gold F & R calipers and front discs, good pads $2000
Rear wing $800
Carbon Undertray (slightly damaged but easy repair) $900
New carpet $450
HKS Hyper exhaust $450
Steering wheel (airbag) $350
Lots and lots of other parts not listed, I have nearly a whole car in bits, so PM me if you are chasing something specific......
Would prefer pick-up in Melb, but can freight at buyers expense.
Prices are neg, but lay off the stupid lowballs pls.
Edited by RPMGTR
https://www.sau.com.au/forums/topic/187420-r34gtr-parts/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
