You dumb ass's
If you think its that sus, you should set the f**ker up and atleast theres atleast one crim that will think twice about f**king with a skyline.
Do what the "brotherhood" always do as standard practice. One word " ENTRAPMENT"
Owell I guess they will go do it the old fashion way huh...
