Originally posted by Ustasa
My partner and I thought by giving everyone 3-4 runs and an explanation of what their car is doing was a good way to build up a repoire with people.
Obviously we were mistaken. If people want a dyno day where making $ is the prime consideration over car performance then I suggest you go somewhere else.
As for our existing customers from this forum and any new people interested in the technical side of things, we are more then happy to have a chat about your plans ;)
I guess this just makes my point. Thank you.
The idea of a dyno day isn't to "build a report" with potential customers, or to have a 30 minute chat to them about "what their car is doing"... Neither is it day where "making $ is the prime consideration".
The idea of a dyno day is to run what you brung, and compare power figures of cars on the same dyno, on the same day. Get the car on the dyno, run it and get it off, so you don't wait around for 4 hours to see your car run.
As for your suggestion of "go somewhere else", I shall take your advice if I ever organise a dyno day, and will pass on your sentiments to anyone else who may organise one. Thank you again.
Merli you have a different perspective on what a dyno day should consist of. I for one enjoy the discussions with everyone while other cars are running and I'm not in a hurry to 'Get the car on the dyno, run it and get it off'. I'd rather have a few minutes to maybe fine tune a few PowerFC settings without having the next person hassling to get onto the dyno so they can leave.
I vote you're first on the dyno for this day being organised.
Anyways, wherever you guys decide to hold this day I'll be there.
Absolutely. That's the whole point. To discuss with other owners what mods they've done, and to see the results.
I take it you have never been to a Unigroup dyno day then? If you're sitting there for 2 hours, and only see 4 cars run, it gets very boring, very fast.
Get the car on, run it, get it off, and you can chat to the owner outside whilst the next car is running.
Performance Forum's dyno day at CRD was *EXCELLENT*... One of the best I have been to. There was a line of 2-3 cars waiting to go straight on, it took about 10-15 minutes per car (depending on power and the level of strapping/ballsat needed)... Run the car, get it off and people can go and chat with the owner when it's off... The car doesn't need to sit on the dyno for 30-40 minutes for you to chat with other owners about their car...
Feel free to pass “my sentiments” onto who ever you wish to :)
At the end of the day we like to know that our customers have the utmost faith in our ability to achieve what they desire. If in the past we have been slow at times then we apologise. But we’d rather take our time and do the job right (like strap cars down properly) then just hurry people up for the sake of efficiency.
After all if the people want to chat and make a dyno “day” out of then we shall do so. Since the majority of people whom I’ve spoken to prefer our way of doing things then that’s the way it is going to stay.
  • 3 weeks later...
I'm not going to bring up everything again but i'd just like to say that i think Unigroup's service is deffinetly 10/10 and i know where i will be taking my car when i need it tuned.
I wouldn't mind having a run at CRD either though coz i've never been there and would like to know where the place is and what services they offer etc.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
