The full undercar kit are sold at $239rrp, but apparantly they don't do them anymore as a kit (wooden box), so the only colour left is pink and it's for $170.
They however do the 36" and 46" individually.
36" undercar neon is $169rrp this order $119 (a pair)
46" overall length under neon is $149rrp this order $104 (a pair)
I reckon if both of them are bought we should get a better discount..... maybe another $10 off ?!
300mm U/V Neon $29rrp this order $23
200mm neon rods $14.95rrp this order $12
590mm neon rods $39.95rrp this order $30
There's heaps more.... strobes, music sensitives neons, etc.... I can pretty much get anything... just email me the colour and length and go from there...
The more order the better, that way we all can save and less freight.
Please do email me to confirm if you do want any. Thanks.
Anthony.
[email protected]
    • Correct, I didn't put GT-R in the same category in this thread, incase I offend anyone. But @GTSBoy  knows my true thoughts on all Nissans.
    • Get more oil pressure sensors. I have 3 purely because trust no-one. It would be worth checking (if not already) if it happens on every shift. Like boring, 2-3 shifts at 60kph making 10kw with no obvious G-force on a shift with mega power. Does it still drop? Does it drop less? What if you shift at 5000rpm or what have you with no load?
    • Unless things that you want to do include reference to time. Simple Boolean logic is only good for digital inputs or analogues that have been thresholded into digitals. But unless you also have a timer function available (which would more ideally be located inside the program, rather than being forced to implement a timer outside the ECU and bring it in as a seperate digital for every time delay you want to implement), then you can't do some of the things that you might want to do. My PLC ladder logics are obviously littered with program blocks, because that's easier than building it all in ladder gates, but the most frequent of those program blocks is a simple timer, because you actually can't otherwise do that in ladder at all.
    • Log voltage. I'm suspecting the alternator. Or even maybe a bad earth somewhere. ie, seeing as it is rev dependent, I am thinking it is alternator dependent.
    • Yeah so N1 and any other larger than factory pump are pretty famous for pumping the sump dry...obviously we don't often get to spend 20 or 30 seconds at high rpm/full noise on the road so I'd still be suspicious that is what is happening here.
