Hey All,
Got an R33 N1 RB26 with Sard 800cc injectors but the fuel is leaking past them back into the engine bay. Its only a small amount, leaving the area around the injectors a bit grimy but it does seem to be affecting my A/F ratio, making it run lean at high revs.
Would I just need to screw them in a bit harder, replace the O rings? (even though they should be new, unless the old ones or wrongs ones were used as they were installed before I bought the car) I dont think it would be a hard job, is there anything I should watch out for?
Cheers!
Gagz
https://www.sau.com.au/forums/topic/187457-leaking-injectors/
i bet whoever fit them used the sard o-rings instead of the factory o-rings..... same issue happens if you do the same with blitz injectors. If in doubt fit new o-rings.... probally 5 bucks at the most. remmber to visit your bedside table and vas them up before fitting too :D
Hey Uras,
Thanks for that info, is there anyone on SAU that sells the OEM o-rings? Got a Nissan dealer here but they are pretty dodgey. Also is it just a matter of disconnecting the injectors (after depressurizing the fuel system), removing them and putting the new o-rings on, and coat them in vaseline (thats what you meant when you said vas them?) and reinstall? If so then I can do that easy.
Cheers!
Gagz
If he's talking about the o-rings that seal between the injector and where it seats... then yes.
If you can remove them with the fuel rail intact, then you probably don't need to depressurize the system either.
I did it on my last car (commodore) after leaving it overnight... so when I did pull them out, they didn't squirt fuel everywhere.
  • 1 month later...
Hey All,
Update on the leaking injectors....got some new OEM orings in, going to try and fit them tonight. I have some new info as well on the matter, been talking to Ben at Racepace and he has informed me that quite often its a case of the aftermarket injector not seating all the way in and causes injector leak. To fix it you need to fit a spacer between the fuel rail and injector to push the injector fully in, Ben said you can get a little spacer piece from Enzed that fit perfectly.
Will let you all know how it goes.
Cheers!
Gagz
  • 6 months later...
Anyidea of the size of the orings or a place to buy them?
Well, the type of places that sell them.
Try to find a place around here that is similar.
Didn't notice how ancient this was, but its better than me opening up another thread... i think..
Edited by Owgasm
lol i bought high temp neopreem ones from a bearing and seal place i bought 20 for under 3 bucks, and they have been working fine for ages, take the injector and the rail with you
Neoprene, I thought, wasn't petroleum / hydrocarbon resistant?
They are Viton or nitrile butadiene.
Edited by GeeTR
Neoprene is wetsuit material?!
Guys ring 0412 013877 in sydney comes to you and will be able to sort you out.. john i think his name was
No one on this forum gave straight answers he does flow test, cleaning and injector seals. have not used him as yet but he quoted me $120 for the whole service.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
