Hi guys, i recently purchased a 1996 s2 r33 gts-t. Im soon to be installing a aftermarket FMIC (proberly Just Jap).
Can any guys who have installed a intercooler kit who have a stock series 2 front bar please write up or show pictures (woulb be better) of what had to be cut, moved or removed completly.
Thankyou
p.s. please no chit chat, just info and other helpful tips or pictures. :D
https://www.sau.com.au/forums/topic/187466-r33-intercooler-installation/
You will have to cut the black plastic bit out of the mouth of the front bar.Cut a hole under your washer bottle for the pipe to come through.But if i were you i would get a dump/front pipe before doing an intercooler.
search the tutorial forum section, theres a guide for the ARC kit (the one that pipes into stock positions, pipe pulls a 180 on the cold side and loops back underneath) and also one for the Hybrid (similar to Just Jap kit) so just search around. From memory though the Just Jap ones require trimming of the fan blades, cutting under washer bottle and trimming of the front reo bar.
heres a guide to where you'll need to cut the hole, under the washer bottle that i ripped from the other thread:
you'll need to cut out the front reo bar in 2 places for the fmic to fit up to 2 existing holes on it (you'll see them when you take the bar off).
ive seen plenty of s2 installs that dont need the front bar to be hacked into with the JJ kits.
its the series 1 bars that need butchering.
I noticed there are two small items i think they are the horns in front of the radiator behind the front bar, do they need to be relocated? does the bar behind the front bar need to be cut to fit the cooler or compeltly removed?
I did look at the two guides, they wernt much help. The Arc kit guide was great, but im not using that kit, so i need to now for a JJ kit. Does the washer bottle need to be re-located? dose the front intrusion bar need to be cut into or removed altogether.
If you cna find any other links for install. please put them up :D
yeah i just installed mine and haven't put the horns back on yet not sure where a good spot is yet, I got mine in without hacking the reo also I hacked my thermo fan and front bar lights instead eek!
Edited by SevenAngryPenguins
Got any pics of it all installed? wot did u do with ur washer fluid bottle?
yeah i just installed mine and haven't put the horns back on yet not sure where a good spot is yet, I got mine in without hacking the reo also I hacked my thermo fan instead eek!
I installed the JJ kit on my s2. No trimming of fan or moving horns. Have to cut the centre section of bar out, a little out of sides of bar to allow room for pipes and cut a little bit of plastic bracket off washer bottle if you have to. I also got my mate to weld on a nipple for the boost line. Quite simple, just take your time cutting the front bar as you don't want to cut too much at once. I'm happy with the kit, looks awesome! :blink:
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
