Guest Sim32
17..wow..hey mate ive been in 11.4 seconds yellow r34 gtr v spec..and let me tell u this is one of the most phenomial cars i have ever been in..alongside a ferarri f355 :) not even for straight line speed..but just for handling..the whole setup is great..but yeah..even standard u will be suprised...
so have fun..just make sure u pay the phat insurance bill :(
https://www.sau.com.au/forums/topic/18747-hello/#findComment-394364
lol, i have a quote for insurance at almost $7000, so since i still live with my parents they have agreed to register the car under there name so i could get it insured for $850 a year. The only problem is if i crash it, i will have to pay a shitload extra :) but i dont plan to crash such an awesome car !
https://www.sau.com.au/forums/topic/18747-hello/#findComment-394371
using money from your trustfund to buy a $80k+ car as your first car is the stupidest thing I have heard, and your parents letting you do it is even funnier.
why dont you wait until your like 25, and on a rating 1 or something, start with a cheaper car so you can get some driving experience, and cheaper insurance as well as easier rating. you gotta taste the sour before you can appreciate the sweet :(
but good luck to you none the less, your gonna need it :)
https://www.sau.com.au/forums/topic/18747-hello/#findComment-406298
God, i think some of the old boys here have forgotten what it's like to be 17. No matter what anyone tells you, you don't listen. If you've got your heart set on it and it makes you happy then go for it. If he's telling the truth, then nobody here knows what his situation is.
But, still, if you asked me, i'd say buy something with a little less power to start with. At 18 and with no real serious driving experience, even a simple r32 gts-t can get you into a lot of trouble if you don't know how to handle the power.
https://www.sau.com.au/forums/topic/18747-hello/#findComment-406423
yup me being 17 we dont listen to the old folk we figure things out for ourself either the easy way (buyin a cheap car) or the hard way (buyin the gtr and gettin killed by the insurance) let him learn if he wants to blow $90k on a car and im betting over $5k on insurance a year let him he'll learn
https://www.sau.com.au/forums/topic/18747-hello/#findComment-406439
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
