Originally posted by fatz
the quater mile with corners
:bahaha:
We should just put a picture of a straight line and a big red cross going through it. Form the ancient secret society of the "No straight liners"
Yeah, in for a few (4), but you'd be really brave to try and use a photo with cars in it :)
Needs to be long sleeve and light cotton so not too hot. SAU logo would be great.
How about "Team Trackday - Too Good for Slogans" :)
Other option I was looking for was just an empty corner on a track but couldnt find a decent photo.
Originally posted by Silver-Arrowz
:bahaha:
Silver after watching a member of your team trackday have a run down the straight line :bahaha:
I'd be quick to put picture of a straight line and a big red cross going through it too :bahaha: :bahaha:
Hey Buster,
I may have mis-understood, but I think your comments are really uncalled for man, especially if it is about someone here giving motorsports a go.
Now back on topic...
Carlo,
I really appreciate your effort into the Team Trackday shirt.
Can you put the Logo " Team Trackday....Following no Line!"
thanks
akira
Please PM me your phone number, as you have no idea what you're talking about and more to the point you would have to know what I paid for my black car to know how much my white car cost me
Do you know how much my black car cost me?
My comment was merely a light hearted dig in the ribs at you track guys who think there is no skill involved in straight line racing, it was not worth you jumping in and making an enemy of me who you don't know and have never met!!
Originally posted by akira
Hey Buster,
I dont know you so I dont have anything against you, But if you wanna diss anyone from Team Trackday........
I'll be happy to post up the cost price of your White R33GTST at Auction in Japan and how much you overpaid for your car ;)
In other words, if you cant say anything constructive, go post on Fast Forums where there are plenty of Ego Maniacs just like you.
akira
After stating you don't know me you then jump in and openly threaten me that you will post the cost price of my white car and that I should be posting on Fast Forums because I'm an Ego Maniac
Maybe AKIRA it is you who is the ego maniac and should be posting on Fast Four Forums as you had 3 choices
1 you could pm'd me that my post insulted you and asked me to delete it which I would of been happy to do because I am NOT an ego maniac
2 you could of emailed me and asked me to do what I've wrote above
3 you could of done nothing as you don't know me and there was no need for you to have a go at me
BUT instead of that you act like a big man with a huge EGO and openly insult me on a public forum, I hope it was worth it
Judging by your reaction, I must have mis-understood your light hearted dig to be something more than what its meant to be.
Now that you have explained your position, I am satisfied with your explaination and have no further issues.
Several people here know about your current car because they have access to auctions in Japan.
You should consider joining us in Future Trackdays. The way your car is set up it should do well too. You can even buy a T-shirt off Carlo ....;)
Carlo,
Can you print up BroTec shirts?
I would still like to know if you know how much I paid for my black car which I traded in on the white car, I bought the black car off yahoo JP so I very much doubt you would have a clue how much it cost me and would be very surprised at how cheaply I was able to get into the white car for but as you are not my friend and never will be as I don't like ego maniacs like yourself you will never know
In future posts Akira maybe you should take youyr own advice
Guest
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
    • Not in any way a logical conclusion. Also, looking at those logs, I struggle to see how that much oil pressure can go away that fast unless you are sucking air into the pickup. Meanwhile the ECU voltage is chucking a huge wobbly which seems to be tied to the throttle position. 100% throttle results in decreasing voltage. It's a mess.
    • So didn't get around to installing a manual oil pressure gauge and then decided to take the car for a cruisey drive to a cars and coffee and brought the laptop along with to get another log using more gears to see if its an oil pressure issue under acceleration or after. this log has 3 gears of WOT where as previous had 2 and the oil pressure dropped once on the brakes, and the same again happens here which is interesting as it shows it can hold oil pressure while under acceleration but once slowing or just the lower RPM after a pull pressure drops. I will be chucking a manual oil pressure gauge on to confirm but so far this makes me feel it is not an electrical issue. Something else i realised is the pressure sensor also is giving temperature information and the temp stays steady the whole time which makes me feel like the sensor itself is showing a true pressure reading.
    • LOL.... fk...   there goes 25K to make 200kW
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
