Hey guys got my compression test results on my Rb26DETT as follows.
176 180 177 155 150 170
There is a diff of 30 between cyl 2 and 5 :S Is it worth throwing on some aftermarket turbo's and power fc etc or does it look like rebuild time?
How long do you guys think the engine might last? Seems to run fine? Thanks!
https://www.sau.com.au/forums/topic/187549-compression-test-results/
Should i get a leakdown test done next? Thanks!
I wouldn't break out the cheque book just yet guys. there are a couple of things that can give incorrect results. I would be happy with 150 in all 6 cylinders as long as it's even. how was the test done? hot? how much time cranking? what type/brand of gauge? how good is the battery? throttle open?
i wasn't there when the test was done but it was done by a reputable performance shop. I'm getting another compression test and leakdown done on tuesday so when i have the results ill post them up! I doubt the engine could be that bad.. the car is standard and runs very well! nice and smooth good pickup and idles perfect
I have done compression test on my rb25 and the numbers were 180psi,190psi,180psi,180psi,180psi,190psi, I was surprise with the #, then I went to check the fsm and the fsm says factory is 185 maximum and 150psi is minimum for the motor to be good and a difference (I don't remeber exactly right now) but I think was 15psi between them, so I was really surprised and I've checked to see if I had a rb25de turned to rb25det and my motor is for sure a rb25det not tuned to be a (t) so I went to check my cams and apparently they have been changed (new gasket all around the valve covers,I have to open to see what cams do I have still), so I think the best you to do is, do the compression again this time make sure if you have the battery fully charged no spark no fuel and wide open throttle, turn the ignition for about 5 to 7 seconds and make sure your tester is ok too.
This is what I have done, I'm not 100% sure about rb26 but that is what the fsm says to do for my rb25det.
I hope your motor is ok man!
gl!
Hey guys well I am happy to report apparently my engine is fine. Wen't and had another compression test done at a very reputable place and also hot and cold leakdown tests done. Compression was 150 on all 6 cyl and on the leakdown just said "nothin to worry about all less than 10%"
I dunno why it came up with dodgy readings the first time but i'm happy with that result!
Cheers
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
