Supersprints and Hillclimbs are different to commercial track days as they are full, CAMS sanctioned speed events.
Supersprint:
Timed runs (normally 1-3 laps) around a race track with 2-4 other cars. You will be timed within your class.
Hillclimb:
Timed runs up along a track/road (up a hill!), one car at a time.
Any CAMS event will make "supplementary regulations" available which will explain the requirements. In general, you just run your road car with the following:
* Fire extinguisher mounted in the cabin (about $40)
* "Secondary Bonnet Tie Down" - any simple rope/strap that holds your bonnet closed in addition to the normal catch
* Blue triangle on the car pointing where your battery is (can just use electrical tape)
* your competition number on the side (can also just be tape)
These changes are all pretty simple and should not need to be permanent mods to your car.
You will need:
* Full face helmet
* Neck to foot clothing
* CAMS L2S license, currently $91 thru CAMS or the club.
More detail from the cams site is here:
http://www.cams.com.au/content.asp?PageID=...rted&ObjectID=6
There are regular drag races at Eastern Creek on Wed nights from 3pm-10pm. If you get there around 3 you should be able to have 4-5 runs in that time.
Bring along:
* Registered car, bring along rego papers (and a letter confirming you can run if the car is owned by a company)
* Driver's license
* helmet
* long clothing
Full details are on the Eastern Creek site:
http://www.eastern-creek-raceway.com/offstreet.htm
Full circuit racing is a bigger comittment than hillclimbs and supersprints.
To drive you need:
* Helmet
* Race suit
* Race boots
* Fireproof socks
* optional fireproof balaclava and underwear(!)
* CAMS L3 license or higher (requires approved observed license test, eg thru race driving course, flags lecture, medical exam) current cost is $465.
You can get hold of the racing gear from shops like Race and Rally
As for your vehicle, you can either lease a prepared car for a race, or put it together yourself. CAMS have full details of the requirements for each category.
  • 1 month later...
My thoughts on the subject....
If you are sensible about it you can take any car on the track. Just drive it within it's limits and your's.
The idea of a track day is different for everyone. I go out there to drive fast in a safer (and legal) environment to the road. I do a few hot laps and then let the car cool down. Tyres, brakes etc can cop a beating on the track IF YOU DON"T LOOK AFTER THEM.
A brief checklist I do:
Bleed brakes before every track day.
(Using DOT 5 or higher fluid in brakes)
Check condition of brake pads (more than 1/2 left is a guide).
Check cond. of tyres and inflate to correct pressure.
Check all wheelnuts torqued to correct spec.
Change engine oil (usually coincides with oil change time anyway).
Check all other fluid levels.
Visually check (and do the grab and shake check) suspension for any obvious problems.
Now if you think about it they are all things you should be doing anyway, even if you are only driving a car on the road....
Frank Williams does NOT use track days to recruit drivers so there's no point pushing it. Wait until you get familiar with the track/car/yourself before trying for the lap record.
Everyone should do it at least once in their life.
:D
  • 4 months later...
If you're serious about supersprints it's also worth getting a spare set of wheels and fitting them with street legal competition rubber such as Dunlop DR01's (or 02's) or Bridgestone Potenza 540's. They're worth atleast 2 seconds a lap on most circuits.
Gordon Leven Tyres at Emu Plains sells Bridgestones and Gary's Race Tyres at Blacktown sells the Dunlops. My 540's are 235x45x17 and cost $360 each.
Of course, if you're prepared to buy competition rubber you'll get the most out of it if you install a suspension kit as well.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
