For Sale:
Skyline R32 GTS, 1992 model, 5 speed manual
Engine conversion engineered to an RB26 twin turbo with R33 GTS-T gear box
Gunmetal grey, 18 inch Traffic Star Rims
Engine only done 7000kms, car done 180 000kms (new forge pistons and rings), bored and honed, head service (fully ported and polished)
New exedy clutch
GTR brakes & hub upgrade
Limited Slip diff
3 inch exhaust and hi-flow cat
Runs 12s with amatuer driver on soft tune
245kw at the wheels
$17 000 neg.
Contact:
Erin
Edited by em_janeR32
  • 1 month later...
  • 1 month later...
Any problems with the car?
Has it been in any accidents in the past?
What is the reason for sale?
Any modification done to the engine?
When the engine was rebuilt have you put new turbos on or have the old ones been rebuilt?
Any modifications done (excluding previously stated exhaust/cats) to the car or is the engine totally stock?
Any cosmetic scratches or dents on the car?
Can you post more pictures of the car especially the interior with the seat covers removed?
Would you sell for a lower than 15k with stock wheels?
Edited by UNTS-1
There are no problems with the car.....I have alwayz used it as an everyday car and therefore had to ensure it was in good condition for daily use.
In the 2 and a half years I have owned it there was one accident where I was nudged from the back before all of the modifications began, which managed to hit only my exhuast and pushed it up.....the whole exhaust system has been upgraded and replaced to suit the rb26.
I'm selling due to buying a house.
It still has the original turbos on it, they were still in good nic
Engine is stock except for performance maintenance like porting, polishing, honing etc.
Being an older car there are scratches but still remains in good condition
I havent got any other pics of the interior atm. there is only 1 small rip on the drivers side seat.
I'd like to keep the wheels on it as I have no use for them when the car is sold.
Any other questions just let me know.
Thanks
Erin
Where was the conversion done?
Do you have receipts for head work etc?
The conversion was done at home with my ex-bf who works for Croydon Racing Developments who can vouch for all the work done by himself and my father (who built drag cars). I don't have receipts for head work.
i got 16.5 for my 300+ ATWKW GTR, why is yours worth 14?
I will give you 8.5 cash. Tomorrow.
I'm going off current market value...including those advertised on here with most GTRs being sold for around 16K for basics or more and considering u were sellin it for 18K to start off with says sumtin. I believe it is well worth the money and good luck finding a similar find any cheaper. 8.5 cash u have got 2 b jokin.
I started at 25 for the gtr, it was up for sale for 8 months.
But any who good luck with the sale it is definatly a tidy 32.
Thank you.....I have looked after it well
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
