oh so he sends Ferah pictures message's of his new shoes for his line
but wont come past my joint to show me
slack c**t...
LoL u have it all wrong LMAO
My friend might be buying Daniels old rims, so i asked him to PM me some piks 4 her...
  • Replies 229
Posted Images
Yeah i'm in 100%!. Would like 25th of Nov aswell, but don't really mind...aslong as the weathers good, but i could always bring out the gtr!
May also have several others that will come along aswell, depending on date chosen.
I still haven't seen your 33 :P
list updated.
pav: got held up up, thats y i couldnmt make it.
ferah: will send u a pm when i get home from work. (ur friend saw them on the last gor cruise tho?)
25th is leading, poll will stay on until mondy 15th october, u have another 10days to vote for your preferred date
come on guys....for the emsta's sake change the date to 2nd or 16th of dec....
I COMMAND Y'ALL TO VOTE FOR THOSE DATES!! ;) :sorcerer:
I think we should start bribeing everyone emsta so they dont have it on the 25th... i bake pretty good brownies :(
Hey all, kevind's daughter here...i came on the recent Sorrento cruise in dad's GTR...also went on the GOR cruise in my brother's Pulsar (SRZILLA)...had an awsome time with both ofcorse
so i was excited to hear that another GOR cruise had been organised so this time i could go in dad's car on the twisties :) BUT the 25th of november is the day i fly to the sunshine coast with
the mother for a weeks holiday after exams finish and the 25th looks like the most popular day...
I reckon it should be on the 2nd Dec: 1) Because it will officially be summer!
2) Another week may give some people the chance to go if they cant also make it on the 25th
3) More time until the cruise so techincally there could be more cars!
Oh and if its on the 2nd i'll be able to go aswel :D (thats really the main reason)
Thanks
Lauren
hey dan i might be able to do the 12 of jan just got to conferm when i go back to work please make it so i can come.
altho the car may be in the work shope getting tuned after new cam, gtr fuel pump, 440cc injectors, and ecu go in
Guest
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
