All,
This is my fiance's car, and current daily driver. She has owned it for approx 2 years, prior to that owned by another forum member since brought into the country by a dealer in 2001. Now for sale due to upgrade.
1994 RB25DET 5 speed
Black, straight with no damage
95,000kms with full history in AUS, recently serviced & major service complete (timing belt etc).
Has 6 CD stacker & Razo gearknob
Limited amount of modifications (reciepts available as per previously owner)
APEXi split pulse dump pipe
APEXi front pipe / 3.5" cat back
APEXi AVC-R
APEXi SAFC
K&N panel filter with airbox
HKS Turbo Timer & Boost Gauge
The vehicle only runs 6psi day in day out. Has made 202rwkw @ 10psi with dyno sheet available.
Don't come and see it unless you are ready to buy.
Priced to sell at $12,490. Flexible on price if some/all modifications removed.
Edited by Morgs
https://www.sau.com.au/forums/topic/187636-1994-r33-gtst-12490/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
