There is a large thread that covers everything for the RB30 build.
If you use standard non turbo RB30E Pistons and bolt a RB25DE/T head on it will drop compression to around 8.2:1.
If you want a compression of around 9:1 you will have to go for custom pistons.
The standard RB30E Rods are extremly tough. Shotpeened & cleaned up etc.. will see them through to 300-350rwkw.
The RB30E Bottom end is 30mm higher than all of the other RB20/25/26 Blocks. So you cannot use RB30E rods in a RB20/25/26 block.
If you were to use RB25 Pistons you would acheive an extremly low compression ratio of around 7:1
https://www.sau.com.au/forums/topic/18765-rb30det/
Hey Sumo,
That's a great thread, read it again, I'm sure you'll learn a few extra things the second time round (I did).
Anyways... there is a PDF file posted in that thread which specifically outlines how to get VVT working.
I can't remember 100% but something like you use the oil feed from the block to operate the solenoid for the VVT in the head.
Check the thread again and look for the PDF.
Cheers,
SXTACY
https://www.sau.com.au/forums/topic/18765-rb30det/#findComment-395027
Originally posted by SXTACY
Hey Sumo,
Cheers,
SXTACY
SXtacy i believe that your were going to drop a RB26/30 hybrid in a silvia, did you do it? how where the Twin turbo exhaust dump and downpipes? also i cant find that pdf what is the name of it?
and did JNR24 ever post his RB30 engine swap guide thing?
https://www.sau.com.au/forums/topic/18765-rb30det/#findComment-395036
Hey 93:
Here is the link for that PDF:
http://home.iprimus.com.au/mawler/RB30DET.pdf
Posted by Joel.
On the VCT topic, 25t posted this:
"To solve the VCT oil feed problem I removed the Vct solinoid and drilled straight down the vvt oil feed galery through a brass plug and into the cavity which houses the VCT solinoid. "
Regarding my engine... it won't be completed anytime soon (like maybe at the end of the year). I was doing the project as a sideline because my main project is my S15 which has a HKS 3037 and full engine rebuild and a host of other goodies that I'm trying to finish :)
With the RB30/26, I was going to drop it into something crazy like an S13 or I may lose the plot and put it into my S15... now that would be different :D
Cheers,
SXTACY
https://www.sau.com.au/forums/topic/18765-rb30det/#findComment-395045
There will be a final PDF made up and should be ready in the next week or two.. Hopefully.. :)
RB30E Pistons in AUS are from Nissan $720AUS.
Big End and Main Genuine Nissan Bearings are $250AUS.
I was going to used Forged ARIAS Pistons ($1600AUS) then decided against as I was chasing 300rwkw (402rwhp) which would require so much more outlay not just pistons (i.e external wastegates, Big injectors, more money cleaning up rods etc) For 260rwkw (348rwhp) I can get a reliable RB30DET that is making full boost by 3000rpm and pulling to 7000rpm. If you want 300rwkw you need to spend money basically.. :) For mid 250's (335rwhp) you can get away with a stock bottom end.
Mathoon is making 320rwkw (428rwhp) and is still using the standard Nissan bearings. He didn't go with the Nismo ones. It really depends on what the car is going to be used for. For a street weapon I would stick with the Nissan Bearings unless you don't mind spending a little more for the Nismo Bearings.
With the 4.33:1 Ratio diff the R32 runs the RB30DET should feel really pokey even off boost and due to the 7000rpm rev's I will still be able to clock 250km/h..
I slapped the rear wheel horsepower conversions in for the US blokes :D
https://www.sau.com.au/forums/topic/18765-rb30det/#findComment-395248
Originally posted by -Joel-
I slapped the rear wheel horsepower conversions in for the US blokes :)
Why not make it truly universal and talk about power at the engine. The US fellas will be using different dyno's to us, so talking about rw power is even less relevant than it is among ppl using the same make dyno. If I remember right, their dyno's would read higher for the same power as us. So 300rwkw to them is equivalent to 250rwkw to us (for example).
Its something that really irks me. What's 300rwkw anyway? I can ride a pushbike on a dyno and get that number with enough operator fudging.
Don't mean to single you out Joel, been meaning to say this for a while. Power at the eninge. Its the only goal to set.
(Really, whats your goal (300rwkw) at the engine?).
https://www.sau.com.au/forums/topic/18765-rb30det/#findComment-395488
Power at the engine is the only goal to set, but realistically it isn't pratical. Generally all of AUS's dyno's are pretty close in readings.
I am aware that a rolling road can be fudged but the point is why as when listing mods it will be obvious they are fudged.
My R32 GTS-T on the Dyno Dynamics when it was dead stock made 115rwkw on another Dyno Dynamics at D&T Performance exhaust made 113rwkw on a 34degree day. They are damn close.
I am aiming for around 350kw at the engine which with 30% drivetrain loss average equals out to around 250rwkw.
At the end of the day it is only a guide. Some thing to go by and compare roughly, however the readings should be looked at critically and not taken as gospel.. hrmmm maybe thats a bad example as I don't belive shiet thats in the gospel. :)
https://www.sau.com.au/forums/topic/18765-rb30det/#findComment-395735
Depends on your definition of close, I guess :P. Theres a dyno in Perth that puts out hugely inflated figures (telling me I have enough power to run 11s), and every state will have one of those. Even if the dyno's do put out similiar numbers, theres things like auto or manaul, temp, gear ratio and the operator themselves that change can power output and driveline loss %. Its a fuzzy figure and a real pita to add 30% to get a guestimate flywheel figure everytime.
Its not practical to measure power at the engine, buts that not say its a useless figure. How else do you select a turbo? Or set a power figure to have your head flowed to? Rear wheel power figures don't mean much in real terms.
Thanks, a figure I can get my head around :D.
https://www.sau.com.au/forums/topic/18765-rb30det/#findComment-396117
93RPS13.. I looked in to ceramic coating pistons etc and apparently it increases the chance of detonation however it does reduce engine temperatures slightly and obviously spool turbo's etc earlier as the exhaust gas is hotter and we all know hotter means faster velocity hence turbo spool. This is why some tuners slightly run the car leaner when not on boost as to increase the exhaust gas temp to spool the turbo's slightly quicker.
https://www.sau.com.au/forums/topic/18765-rb30det/#findComment-396990
Hey kwazza11, mate I don't mean to argue (coz I'm new to this forum) but the idea of such a forum is so people can openly ask questions and learn a little from those who know.
We were all at a point where we didn't know what a gallery was...
However, having said that, yes, if you don't know what an oil gallery is, please don't try to do the conversion yourself as there is a steep learning curve you still have.
But ask as many questions you want, that's what this forum's here for - discussion :)
Cheers,
SXTACY
https://www.sau.com.au/forums/topic/18765-rb30det/#findComment-398175
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Gotta admit, I love the 20b Cosmo.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
