you just gotta look out for the drifting geminis that will be going faster than you... :P
but seriously, there arent geminis on the track at the same time luckily.
If that were the case you would be my no.1 perfect customer!
If you choose a holden, try and get 'bluey' as its the newest and fastest or supercheap. If you go ford they are all pretty similar. i usually have 'ice freddy' dont ask where they get some of their names...
Hey Ryan do you have any say in the parts they fit in the cars? I hope you didn't recommend they fit those auto adjusting tie rods?
:laughing-smiley-014:
I did this about a year ago. Great fun but 5 laps isn't enough. And yeah listen to the instructors to get the most out of it. Unless if you get Ryan...
The day I went 2 cars had a sheared input shaft from people grabbing reverse instead of 4th. Does that still happen? Practice your shifting from 3rd to 4th coz that's all you use in these cars at Calder.
people think they can make up a ton of time by shifting as fast as they can. they are usually the people who know very little about going fast but try to. The fords have got a hardened input shaft now, which makes them last longer, but they still break eventually. same with the whole driveline, eventually they break, but its usually someone who flat shifts or tries hard to get it into the wrong gear that seals its fate.
None the less, its impressive how much these cars hold up to. in summer on high 30deg days they go all day (8hours) and rarely miss a beat. You could drive them on the limit all day if you look after it.
  • 1 month later...
make sure u get the new 6L VZ they have, i think they call it nemo (it was a water damaged car) then put on the track, when they got it it had head and cam package pulled like 280kw@rears but the dogs pulled the cam out n put a stocker in so as u guys wouldnt kill urselves lol, but it still has a ported head and higher compression then the rest as well as some neat extractors, deff the 1 to go for!
not any more, nemo is now the slowest one out there... there are lots of new ones now that are a lot fresher... strangly nemo is the one that got caught in floods in perth i think.. The one you are talking about would be bluey or fuso. they were clubsports therfore they were quicker so they had to slow them a bit.
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
    • The other trick I've found with wrinkle black is to put the can in hot water for a bit to warm the paint up, and to pre-heat whatever you're painting. It'll be interesting to see if you pick up any power with the intake, following with interest. Got a proper lsd for this?
    • Plazmaman 76mm Pro Series, done. Data to back it up, I posted up somewhere here a few years back
