Diag. Connectors?
what type pf skyline?
most nissans havea grey rectangular diagnostics cable for 'consult' near the fuse box in cabin, search for consult for a picture, its about 4cm x 1cm long
Sorry guys for missing infos, it is a r33 dashboard wiring harness, the car is manual and I have 1 green, 1 black, 1 blue, 1 orange.
I have the green,black,blue close to the dashboard fuse box and the orange on passanger side close to the ecu.
I would like to know them cause a lot of wiring is going to finish at these connectors and I have discovered that most of wiring that is coming (or going) to the trunk ends (or start) at these connectors that is a dead end (or start) for the wirings.
I have disconnected the abs actuator and followed the wirings from ecu to the middle of my car. ( I have the wirings cutted at the front seats because of the wiring harness came from a 95 r33 front clip.)
And because I have a 90 r32gtst and my wirings form the seats back are r32 I'm having problems to find the wirings for: tailights,reverse lights, trunk lights, fuel pump, fpcm, interior lights, sunroof, seats, rear wiper, rear de-fogge, so any info about the wiring color codes that is coming from the front to the trunk will be really aprecciated.
I have found the rl/rr speakers, pw antena, ill., so anyhelp will be really welcome.
ps:I'll post pics of my r33/r32 (front end,motor and dashboard wiring harness)swap asp.
I had one in brown near my ECU with a heap of wires spliced and one near the Steering column, I'm quite cirtain they were for a non fiunctioning Alarm system that had been removed prior to me taking ownership.
 Share
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
    • People just don't understand how good MX5's actually are and how fun they are to drive, park, manuever. You feel like you have got some fun cheat code, while everyone else is sitting in their luxobargeSUV like normies who missed the point of living. It really is that noticable. As long as you/your stuff fit, and you're comfortable (they are), a MX5 is the best car on earth to daily around.
