Hi,
I've just installed RB20 wastegate actuator on my R34 25GTT.
I've got a standard boost gauge which was reading 0.7 Kg/cm2 with standard wastegate actuator (approx 10psi) but now it goes off the scales, that is over 1Kg/cm2 (approx 15 psi).
In terms of modifications all I have is 80mm cat back exhaust that came with the car from Japan, that's all.
My question is - did anyone perform this mod on their R34 25GTT and is it safe setup for a stock turbo and stock engine?
https://www.sau.com.au/forums/topic/187713-r34-boost-upgrade/
I see,
There was nothing wrong with factory wastegate actuator. I've read somewhere on the forums here that RB20 is runnung higher boost then RB25 and that a cheap ($50) and safe (in terms of not getting boost spikes) boost upgrade for RB25 would be to get RB20 wastegate actuator from R32. Those discussions were based on upgrade of R33 ebgines not R34. So I wander if anyone has done this upgrade on R34's and with what results.
BTW RB20 wastegate actuator is a perfect fit on R34's no mods needed (maybe a little longer vacc. hose but that's it).
You can notice difference straight away.
When it starts boosting it's as per normal, you can feel it but when it goes over the standard boost threshold it feels like a second turbo kicks in, acceleration is improved compared to standard.
Well what can I say it's a lot more fun than before and one more thing Bye, Bye STI :D
But it's noticeably hungrier when on boost than before.
sounds good but id be getting a after market boost gauge......when i changed my exhaust the stock gauge didnt read much different to stock.......i installed a aftermarket gauge that reads in psi and it was boosting at 9psi...... ur probly overboosting bad........
maybe it is, I'll have to follow it up with a cheap boost gauge just to see but I will eventually buy a whole centre console nismo cluster ($370) with 1.4 bar boost gauge.
I thought that all skylines or at least 33's and 34's had an overboost protection built into the ECU where it will cut fuel if boost levels will reach dangerous levels, is it correct?
No such luck there mate, you'll need an ebc with a boost limiter there.
Well I'll rephrase my question.
How does it add PSI? I thought solenoid either closed or opened therefore wastegate is either closed or opened which means that there is only 2 states in which wastegate can be not 3 like half opened wastegate and solenoid is there to control those two states (fully closed or fully opened), I might be mistaken. Can anyone shed some light on this?
For those who is interested I did a little reseatch and here is what I found.
"In standard form the R34 runs a two stage boost control system 5psi to 4500 rpm then 7psi to red line 7000 rpm."
"turbo’s exhaust wheel is ceramic and they tend to fail if to much heat is generated. The amount of boost you can run with the stock turbo is debatable but I don’t recommend running more than 10 psi."
"R32GTST wastegate actuator is exactly the same as the R34 except the spring inside is set for 10psi.
R32 actuators can be hard to find but I think it’s the best option for this level of modification as boost spikes and boost creep are eliminated.
No mater which system you choose the 2 stage boost control system should be disconnected."
Therefore I will disconnect solenoid tomorrow and let you know how I go.
Well I couldn't wait till tomorrow so I tried it now with disconnected soleniod. The boost came down to about 0.8 kg/cm2 which is just a little bit higher than stock so I still have minor improvement over stock but I'm a little disapointed. I'll still get an aftermarket boost gauge and give you exact boost figure that I'm running now with R32 wastegate actuator.
Huh well got to look for a steel turbine wheel now.
Can anyone recomend good workshop in Sydney that can change ceramic turbine wheel to steel wheel as I'm pretty satisfied with the stock turbo and connected solenoid.
Another option off course is to change the turbo, any thoughts on what's the closest to stock turbo I can get that has steel turbine wheel and will fit without any modifications?
are you sure you only have a cat back ?
your r34 smic is supposedly good enough for the limits of the stock turby so provided your intake piping isnt sucking closed only your turby will fail in time.
funny how you say your stock airflow restriction was pushing 10psi as opposed to something lower by half. You sound like you already have a larger or atleast better flowing exhuast than stock with the stock valve / gate setup registering 10psi.
from reading here you will be delaminating your turbo's exhuast wheel at an excellerated rate. So you should hear bits of brittle ceramics bouncing around your car provided you still have some guts in it. if not meh would just become dust and fly out anyway.
you dont get r&R ? While driving you get a noticable drop in power while runnig... hell you dont get a sound like your engy is arcing out through its coipacks ? miss fire from your plugs ? lucky bastard......
my s2 33 has 5psi gate with a 2psi hold on stock boost controller so it manages 7psi over 4.5k rpm.. dont know for 34 in this area... since i put a decent if not loud and droning exhuast i do make noticably better power and my boost is roughly 7psi with the stock control gear then roughly 10 over 4.5k. adding a 10psi gate with the stock controller would mean it would do roughly the same @ top end. You wouldnt think this would be the case that with a fixed gate and a controller made to bleed off an extra 2 psi worth that it would be exactly the same. The only answer I have ever gotten on this is the less restriction somehow does this.. without any form of explanation .. good like finding one on here.. I have looked many times without an answer.
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
