hey all got few gauges to rid off so make way for some new ones
Apexi Boost 60mm, reads in BAR, up to 1.8Bar, mechanical $110.
Hks Exhaust temp 60mm mecahnical $120.
Omori ( Oil temp, Oil pressure, Water temp) 45mm mechanical $200 the set.
located in sydney, freight is $10 anywhere in Australia.
Dom
https://www.sau.com.au/forums/topic/187723-apexi-hks-omori/
looks like the HKS zorst temp is goin to jeff, and Apexi boost probs heading nissanpower's way. not certain yet pending response and payment-
the gauge holder wasnt actually for sale...but throw me an offer..
PM's replied
https://www.sau.com.au/forums/topic/187723-apexi-hks-omori/#findComment-3406241
    • I don't run the spring but it means you need to set your own belt tension.  I put tensioners on both sides too.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
