  • Replies 112
  KeyMaker said:
I don't know if I phrased my post correctly.
I was trying to say that if a RB25DET is capable of 270-300rwkw on standard internals, then a RB25DET NEO that has GTR internals would be able to handle even more power on stock internals.
since when can u put rb26 parts into an rb25??? :D i thought nothing was interchangeable
  Bumblebee said:
since when can u put rb26 parts into an rb25??? :w00t: i thought nothing was interchangeable
I probably shouldn't of said gtr internals because that wouldn't be true. I retract that comment.
RB25 NEO has solid lifters & GTR rods (note: not pistons) thus making it a stronger motor.
If anyone has more info on the internals of an RB25 NEO, please add to this.
Correct.
Now a RB25 is safe for around 270rwkw and 300rwkw is starting to push things a little bit and everyone one knows after a while she will go bang. Now with the RB25 Neo, that has some slight different internals, would we say 350rwkw is safe??
Correct me if im wrong, but regardless of GTR rods, i still think 350 at the wheels is going to break something soon on a RB25 Neo.
PS: Still can't believe this thread isn't locked :D
Here we go. Bunch off Mr know it all. Plz. If your a mechanic. Put your 2 cents in. If your not then Plz. Plz all mighty Shut the f**k up. Eg. Ardie. Lets give him a hand for knowing it all. Too bad mate you don't get your little hand dirty bc we all know your a lil shit behind a computer. And we know you don't like getting dirt under your finger nails. We call Guys(kids) like yourself a milky way boy. Or softy. What ever you want to call it.
Seriously, you are pathetic little kid. Cut the f**ken crap..
Just bc you own a skyline dosn't make you a mechanic you dumb shit.
Ardie plz, drop the issue or else. If you keep this up, bad things would come to you.
Requesting a lock down Thank you
Edited by EVLR-34
no need to THREATEN the guy... jeeze
just thought id get it one more in before shes locked.
Edited by jake33
Guest
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
