  • Replies 116
It won't be out for a couple of months yet.
All it will do is basically reduce fuel consumption as the Microtechs at the moment are quite heavy on fuel.
There is also a possibility that the new microtech will have speed input hence traction control. Maybe maybe not. We will have to wait and see hope I guess.
Do a search for LT12 and you will find the users names.. :P
It is a good ecu just make sure when they are tuning that they don't tune the AF's on the limit as you have to leave some head room for cyclinders 5 & 6 as they often lean out. So ... Tune the af's to around 11.8 and you will be fine. Its better to be safe than sorry. :)
How much will they be? Im looking to change ecu's in the next few months. I have a M4 sitting on a bike which doesnt get used, maybee i'll steal that :P
How does that work? How is it a microtech only thing?
Apparently the new Microtech is only going to be a couple to a few hundred more than the LT12.
With regards to leaning out of no. 5 & 6.. It isn't just a microtech thing. Look how many R33's have died recently due to to harsh tuning. It is common knowledge that all RB25DET's run hotter in no. 5 & 6. This is why when flow testing injectors you always shove the higher flowing injectors in no 5 & 6 to help cool these cyclinders down and make sure they arn't leaning out.
It generally happens as soon as you jump over the 230rwkw RB25DET boundry.
So make sure you get a AF print out on your dyno run and make sure there is a little head room left when it comes to fueling.
cylinders lean out because the injectors are blocked.
It's often 1 and 2 or 3 and 4 as much as 5 and 6. The factory plenum distributes air quite well to all cylinders but, after 100,000kms the injectors naturally enough need to come out for a clean.
On my car we had a ping at 4500rpm that did not show in the afr's (it was in the 9's). On consideration I believed it to be a single blocked injector and it turns out it was!
Imagine that. You have ultra rich afr's and all of a sudden you kill a piston.
I cleaned my injector No.1 with a foot spa and toluene, now it's all good.
That is in your case rev210.. But apparently cyclinders 5 & 6 always run hotter than the rest due to a cooling design.
You are right cyclinders do lean out because injectors are blocked but that isn't the only reason.. If you have your injectors on the limit with the stock rail. i.e running 260rwkw through stock injectors with upped fuel pressure cyclinders 5 & 6 do tend to run leaner than the rest. I am not totally sure Sydneykid explained it in a thread some where.
But that is what happens this is why you shove your higherflowing injectors in no 5 & 6.
Sorry to hijack this thread, but while were on the topic of microtechs I was wondering if there are any downside to running a LT8 on a RB20 instead of the LT12?
I bought my gts4 with it already installed and am now a bit worried as everybody with a microtech seems to be running a LT12 and not an LT8? :)
Are there any obvious disadvantages in the LT8? cos i thought the LT8 were designed for 4 cylinder cars not 6's.
Thanks, any help you can give me would be great:)
My old RB20 ran MT8, took a bit of work to get running right (could have been age of car, R31 GTSX)
Like many computers it wasnt that impressive at 1st, but once set up right it did what was asked of it.
Running them on a 6 cylinder is fine it just means you run wasted spark (3 of the 4 ignition drivers run 6 cylinders, so cylinders are fireds in pairs which isnt that big a deal in a road car)
Thats not to far off mine then.. Driving normally boosting etc.. I get 470kays to a tank but I seem to be one of the only freaks that get this type of mpg... Every one else seems to get 400 even sub 400's.
Boosting hard like the other night with the cruise I used 1 needle width under a 1/4 of a tank and did 141 kays... A big chunk of those kays was done at 180kays bouncing on and off the speed limiter so cruising on 180kays I was making 3psi boost just cruising.
I seem to get better kays on a long drive with hard driving than I do with short trips and normal driving (9kays round) driving to uni.
LTX-12 for R33 does not have closed loop. I rang them. It is already out, they just don't have enough production. They won't answer your calls in the morning anymore because they are working madly to produce them. You have to resort to calling the mobile number in the afternoon.
Microtech are at Putney in Sydney.
But they are pretuned for the R33 - you will still need to take it to a dyno real quick because Microtech said they will foul the plugs otherwise as they will run rich if you don't tune and install the air temp sensor. The pretune doesn't have the map for the air temp sensor at all. Needs to be put in while dyno tuning.
You can get R33 standard / R33 auto / and R33 GT models
If you want brand new ones for $1650 pm me.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
