Hi,
When I got my car there was an Apexi EL Boost guage in the glove box,
its the bar type, and on the back is a 3 pin and a 5 pin connector for a plug, but no actual point for the air.
the part number on the bacdk is APE-13485
I assume this is for a system controlled by a computer, does anyone know what type of computer and where i could look at sourcing one?
https://www.sau.com.au/forums/topic/187737-apexi-boost-guage-help-please/
sorry i forget what they are called but go to nengun.com and go to the eletrics section. In there it will have boost guages and the control unit for them, there will be the apexi one in there. :D
I have a working A'pexi boost gauge on my dash.
U can come to Sydney and look at it :P
Don't know sh!t about them sorry. Just know that the barb tube on the back is where you stick the vacuum hose.
At a guess i don't think they're computer controlled. They operate on an air vacuum to give a reading, and the electrical plug at the back is to light the gauge up when you switch on your dash lights.
Hi,
you will not only need the control box but also the boost sender.
is the apexi an EL1 or EL2 gauge,
because by the sounds of your description it is an EL1 which means you dont need the control box. one of the pin holes are uses for connecting power to the gauge, the other pin will connect to the boost sender.
If you can't find the EL1 boost sender just but the EL2 boost sender as it is the same thing BUT if you dont have the plugs to connect into the pins you may have a hard time sourcing them
thanks for all the help guys!
Just to clarify the EL2 will need re-wiring to suit, but a EL1 should be a direct plug and play?
correct but you can only use the sender from the EL2 gauges,
as the EL1 dont use the control box, so they have the second plug at the back of the gauge for the power, ground etc
http://www.apexi-usa.com/pdfInstallation/8.pdf this has the wires from the loom, all i need now is to find a sendor and match the pins to the loom
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
