Plenum Help Needed
SLY33
 Share
Hi guys, decided to run a single throttle plenum setup on my RB28, trouble is im having a hard time finding one!
I settled on the hypertune plenum, but was told none will be made for about 3 weeks.
What other choices do i have for single throttle plenums that are readily available? I'd love to get this motor finished as soon as possible, and ive spent most of the build duration waiting for parts!
If anyone has something lying around please let me know.
cheers
Edited by SLY33
no worries mate :P
theres a fair few threads on www.gtr.co.uk about guys who have actually sent their cars over to rob from the uk! full photo logged buildups aswell.
i must say i havnt seen such high quality and customer service like that ever!
I agree, just looking through their site makes want to get them to build me an engine! They sound like they have everything sorted, well designed packages, their 3 litre stuff looks great, looks like awesome work.
Unfortunately he said it would also take about 1 month to build.. so i guess its either wait for it, and possibly miss out on getting the car 100% finished by xmas time, or just use the nismo plenum that should be arriving any day now..
Bummer he didnt have one laying around.
Top quality stuff indeed.
I'm getting him to do both my manifolds, cooler piping and exhaust, that's how much i like his work ;)
see how exxy his manifolds are.....goddamn. How you going to afford that shane?
easy, he's kiwi, he's use to woking for minimum wages :( (jokes jokes)
NZ $2400 for plenum and 90mm TB is exxy? ;)
easy, he's kiwi, he's use to woking for minimum wages :happy: (jokes jokes)
NZ $2400 for plenum and 90mm TB is exxy? :thumbsup:
2400 NZD is as much 2400 AUD really.
There is such little difference between the two. And with packaging/freight it would be more :)
 Share
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
