after buying 2 radiators to sort some overheating issues i was having
1st was a china job ebay (s13, leaking from the top neck, 20 bux to fix), worked well looked shocking (welds ect)
2nd was china ( r33 worked well but was a prick to fit)
my last car i finally found a china radiator that works a treat and the quality is top noch
anyway they are 50mm welding is tops
no bs good radiator and they fit!
anyway 250 will grab ya one he does them for s13/r32/r33
has them in stock and ready to roll
anyway generally its 30 bux for delivery
anyway i think they are a good thing and they are cheap if anyone wants on
flick us a pm with you man and address and details
drop us the cash and radiator is yours
money details
account mane: peter carruthers
BSB: 112879
account number: 428965807
note i dont make any money out of this i jus though it was a good price
https://www.sau.com.au/forums/topic/187748-50mm-alloy-radiator/
  • Replies 285
Hey Fatz,
Been looking at getting an alloy rad for a while now.. great price!
Do these retain the factory piping?
Who is the Manufacturer?
Anything else required for fitment?
Cheers,
Johno
Hey Fatz,
Cheers,
Johno
factory piping!
manufacturer (china)
anything else not that i know off but the r33 one needs an extra washer to space out the temp sensor (purchased at bunnings for 5 cents)
couple of answers
delivery is a few days if your in sydney
maybe a week anywhere else
these are in australia
s13 i ran thermo fans on (it was a rb30 in the s13)
the cores are duel core (the cores themselves are twice the length of the stock cores.. so the cores are twice the standard nissan size)
supplier is a mate of mine
taking the fan off is the same as a stock core (flexible hands help)
Guest
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
