after buying 2 radiators to sort some overheating issues i was having
1st was a china job ebay (s13, leaking from the top neck, 20 bux to fix), worked well looked shocking (welds ect)
2nd was china ( r33 worked well but was a prick to fit)
my last car i finally found a china radiator that works a treat and the quality is top noch
anyway they are 50mm welding is tops
no bs good radiator and they fit!
anyway 250 will grab ya one he does them for s13/r32/r33
has them in stock and ready to roll
anyway generally its 30 bux for delivery
anyway i think they are a good thing and they are cheap if anyone wants on
flick us a pm with you man and address and details
drop us the cash and radiator is yours
money details
account mane: peter carruthers
BSB: 112879
account number: 428965807
note i dont make any money out of this i jus though it was a good price
https://www.sau.com.au/forums/topic/187748-50mm-alloy-radiator/
  • Replies 285
Hey Fatz,
Been looking at getting an alloy rad for a while now.. great price!
Do these retain the factory piping?
Who is the Manufacturer?
Anything else required for fitment?
Cheers,
Johno
Hey Fatz,
Cheers,
Johno
factory piping!
manufacturer (china)
anything else not that i know off but the r33 one needs an extra washer to space out the temp sensor (purchased at bunnings for 5 cents)
couple of answers
delivery is a few days if your in sydney
maybe a week anywhere else
these are in australia
s13 i ran thermo fans on (it was a rb30 in the s13)
the cores are duel core (the cores themselves are twice the length of the stock cores.. so the cores are twice the standard nissan size)
supplier is a mate of mine
taking the fan off is the same as a stock core (flexible hands help)
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
    • Throw between gears are so much that is getting annoying. I have pro short shifter on my mx5 and e36 and love it . Skyline is getting unbearable    would syncro issues and short shifter is no no? Anyone mind explaining a little on why before i buy cube
    • No. Well, some people "seem to use redline shockproof in the diff". Most do not. I would only contemplate it if you have badly worn CW&P gears. And no. No-one in their right mind has ever put ATF into a diff. Any normal diff/gear oil of the right viscosity will do. Whatever takes your fancy. Castrol, Nulon, Penrite, Redline MT range. Whatever. It's just gears. 75W-90 or 80W-90 is typical. I think that GL-5 is hard to avoid these days, although I think that a GL-4 is probably preferred, given the vintage of the equipment. At least Redline offer a number of GL-4 oils. If you have a clutch type LSD instead of the VLSD, then of course you need a proper LSD oil. Anything from any of the same names above. If you have a helical LSD, then it does not require LSD oil, and the recco is the same as for the VLSD. You don't want the LSD friction modifiers in the oil for a non-clutch type LSD if you can avoid it.
    • You may want to list it up for a little higher - This price is much lower than you may realize. Here you're pretty much selling to people who most likely already have these things on their own rigs. S chassis people eat this stuff up like you'd not believe.
    • I had my car for over 10 years and done around few thousand miles but never changed the oil. thinking of changing it.   what brand and viscocity would you put in ? people seem to use redline shockproof in the diff   on  contraty seen others using atf dexron 2 or 3 so wanted to check. is it 1 liter?
