have spoken to John at UAS and they are having trouble getting the radiators, maybe 2 weeks wait. So if you have ordered one its gong t o be a while
SLOUCH- he is away for 2 weeks and john at UAS is the man to speak to about them.
  • Replies 285
Make sure to check if there is a voltage in the coolant, else it wont last too long.
How?
You need a multimeter set it to Voltage DC, with the car running put the negative test lead to the chassis(better to the neg of the battery). Put the positive lead into your coolant via where the cap is, be careful that its only submerged into coolant and that its not touching no metal. If you get a reading > 0.3VDC you have a problem and the radiator wont last very long.
If you get a reading over 0.3VDC make sure you replace your coolant, try the test again after replacement.
Grounding the radiator wont cure the problem! You need to find the faulty circuit which is inducing the stray voltage. Start removing fuses until you find the voltage drop, then its a matter of adding a bigger ground for the found bad circuit.
Try googling "aluminum radiator electrolysis" if you are after more information.
*You will need to go to supercheap and buy 3 copper washers for the temp sensor.
Ok a bit confused here. I had my alloy radiator fitted several months ago and I didn't need any washers. In fact, there was nothing connected to the radiator other than top and bottom hoses. weren't any holes in the new rad either for a temp sensor to slide into.
anyone care to shed some light?
also, car takes a VERY long time to warm up in the morning. temp hits normal after a good 5km of driving, so about 15 minutes. is this normal? i have a nismo cap on it (1.3 bar).
Think his talking about the water coolant temp sensor located just after the end of the top radiator hose (engine side).
Don't understand why you would need washers there.
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
