Hey guys,
I removed my spoiler from my R33 to go the no spoiler look and obviously im left with holes where the spoiler bolted too. I was just wondering if anyone has had these holes filled in and how much i'd be looking at to get this done?
THankyou very much :D
we just charged a customer $500 to weld all the holes (3 on each guard, and 4 on the bootlid) and prep ready for paint. We found that just bogging as a lot of companies do results in shithouse dimples later down the track when the bog shrinks.
put a vinyl graphic on your boot, or better still cover the boot in black or carbon look alike vinyl... gloss vinyl will look just like it is paintedm you won't be able to tell...
yo 75coupe... can you colour match vinyls? what are your rates to cut a design on a 1m sheet of gloss vinyl in S14 burgandy... i'll supply the eps/vector art.
I don't know if you could actually colour match it, you may be lucky to find the vinyl comes in that colour, if its not metallic.
The colour range in vinyls is quite large...
And if you print it onto vinyl it will look flat look tacky...
you would be after a sign shop, they should have a colour book for you to check out...
Unfortunately I don't know any burgandy 32s otherwise I would match it for you. I'll let you know if I find one...
thanks lads, i'll have to get around to some panel beaters to get prices.
just thought i'd ask to see if anyone had it done and how much roughly the damage to my pocket would be...
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
