Hey I was wondering if anybody could tell me what fog light and park light bulb to use if I am looking for a white with a hint of blue colour light. My friend just bought me a set of H1 Ultra Power Bulbs that is coated blue (which I have read gives off a white with a hint of blue) and so I'm trying to make all my lights the same colour. I did a search on this and found somebody using Phillips Blue Vision for his fogs and another a "5w wedge bulb same as dash lights". Are these any good and do they give off the colour I want?
So yeh, any help would be appreciated.
Thanks,
Rian
https://www.sau.com.au/forums/topic/187794-headlights-bulb/
Whilst I don't know the exact answer, I can tell you that just because the globe is blue does not mean it will give off a cool white light... I tried matching my parker bulb which was a nice cool white glow of love and hapiness and found what I and the parts dude & I thought were the same and d'oh it has the boring old amber light...
Edited by 75coupe
https://www.sau.com.au/forums/topic/187794-headlights-bulb/#findComment-3388425
Point taken. Well I just researched it then and my bulbs does give off a cool white light. So yeh, any ideas on what fogs and parking bulbs to get that gives off a cool white light?
https://www.sau.com.au/forums/topic/187794-headlights-bulb/#findComment-3388471
you should also know what is legal and what isn't if you go to a bulb that isn't ADR approved and crash at night your insurance company may not pay up.
phiilips blue vision are the most whitest legal bulb in their range. the crystal and diamond vision aren't ADR approved. also blue vision bulbs are only as bright as a standard bulb (crystal and diamond are duller), so if you actually value being able to see at night i would suggest getting a better bulb like a +50 and be able to see better than being a ricer with cool lights but can't see very well.
https://www.sau.com.au/forums/topic/187794-headlights-bulb/#findComment-3389174
So where can I find out whether the set of bulbs I got are ADR approved or not?
And sorry about this, but are you saying that the philips blue vision is good or bad? And what is a +50 bulb? I've never dealt with headlight bulbs before, so forgive me for asking a lot of questions.
I'm not trying to go for a ricer look or anything like that. I'm just trying to find a set of bulbs that is as good as the std, if not better, but gives off a cool white light instead. If there isn't any, good ones, I might just stick with the std.
https://www.sau.com.au/forums/topic/187794-headlights-bulb/#findComment-3389398
they should say on the packaging if they are ADR approved.
phillips blue vision bulbs are good. i had them in my r33. they are a whitish light. +50 bulbs are another phillips bulb. they are designed to be +50 brighter than normal bulbs, but still the standard colour.
i had a mate who had very blue bulbs as his high beam in his 33. on high beam the lights shone far ahead, but it was hard to see. it was very dull (if you have every seen a blue LED keyring and tried to use it to see something in the dark you will understand). you could drive round on them and not get flashed but you sort of struggled to see things.
blue lights are much better in the fog than white and yellow, but yellow are the best in the wet.
https://www.sau.com.au/forums/topic/187794-headlights-bulb/#findComment-3389518
Hm.. all I got on my packaging is "E MARKED ROAD LEGAL". So I don't know whether it is referring to here or where ever the bulbs were designed to be used (which I think is the UK) :S.
Well I guess since the philips blue vision are as good as std, I'll probably get them. I wouldn't want them to be too strong anyway, since it's only being used on the road.
I can understand what you are trying to say about the LED keyring though because I remembered going camping with a mate who brought something like that as his torch and it could see wide and far, but as you said, was very dull and poorly concentrated.
So yeh, thanks a lot for your help on that mad. You wouldn't by any chance also know of any good parkers that gives off a cool white light would ya?
https://www.sau.com.au/forums/topic/187794-headlights-bulb/#findComment-3389591
phillips blue vision bulbs come with parkers that are the same colour as the bulbs. (they also make great lights for your dash. makes it look like there is a fluro behind the panel)
as for the LEDs i was just mean the bright blue LEDs. the white LEDs that they use in torches are ok, but any light that is to blue becomes duller.
https://www.sau.com.au/forums/topic/187794-headlights-bulb/#findComment-3391823
Oh ok then. Thanks a lot for your help mad. Appreciate it.
https://www.sau.com.au/forums/topic/187794-headlights-bulb/#findComment-3391953
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
