dean.. con has one on his the TR43 or some shit.. external gate.. for a smallish size turbo it doesnt have anything under 3,500rpm and made 215kw with 14 or so psi... supported with a microcrap and the rest
Well our turbochargers do require a running in peroid of 1000KMs. before that has been done it will appears to be laggish as the Journal bush needs to be worn in and the core needs to be libricated by oil.
Lot of tunners dyno tune the car straight after the turbo's installation and obviously it will not give the best result. The power out put of the car also depends on the tunner.
the turbo has been on for more than 1000ks.. ok its a cheap turbo and bang for your buck.. but for a smallish turbo on a 25det with supporting mods, im unimpressed.. but it does have good torque
We just made 230kws on 14psi with a fully standard engine, Stock cams, Stock AFM, Stock injectors. Please PM me a copy of the dyno read out, I'm really ken to see it. For some reasons I believe the turbo that you dynoed was a TR44 or might be not one of our turbos.
Also just want yous to see a comparison between a 440HP Ball Bearing turbo on a RB25det with a Our TR43 on a CA18det and TR43 on a RB25det
440HPBB RB25det turbo maxed out @ 240KWs with injectors, Max boost 25PSI @ 4798RPM
TR43 CA18det 230KWs MAX (keep in mind this is a 1.8L 4cyc engine). Max bost 25PSI @ 4658 RPM
TR43 RB25det 230KWs MAX Factory injectors leaned out @ 14PSI
Power compare with RB25det TR43 vs RB25det 440HPBB
RPM_______________3000_ 3500_ 4000_4500_5000_5500_6000_6400
TR43 Power(KW)______111__130__155__185__202__210__225__230
440HPBB Power(KW)___60___75__ 100__145__210__220__221__230
And as I repeat the TR43 RB25det fuel leaned out, and dynoed with only 14PSI.
TR28kai 340HP vs 300HPBB turbo
but isnt the TR44 rated higher than the TR43?
yes. TR44 it rated 50KWs higher, Bigger, also slight laggier. Here's a dyno read of TR44. the 1J made 240kws on 14PSI@2350RPM, and 276KWs on 16PSI@2400RPM with 50Nos.
Edited by hypergear
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
