Hey guys, is there any tips for cleaning engine parts after stripping them off? I have been soaking them in degreaser and cleaning mine so far with good results, but is there anything else I can do to get them to come up like new? I was thinking of using CLR but it seems like a fairly general purpose product and not confident it wil do any better than degreaser. Thoughts??
Use degreaser, it is the best bet. I usually wash my parts in hot soapy water and rinse in clean warm water and dry if I want/need to get the degreaser residue off. Most degreasers are either phenol, TCE, PCE, caustic or more commonly kerosene based. All derivatives are made up of what they call abrasive products - that it, they are not new engine friendly. You can use degreaser as a first clean, but I'd finish with another product that removes degreaser residue.
You could use a few products, but water etc is the cheapest. Don't leave any iron/steel exposed for too long though, get it dry and coated with a light oil.
BTW I have mates that use degreaser and nothing else, and it works for them, they generally use a light running in oil and then do an oil change early.
I wouldn't soak things in degreaser for too long [depending on the degreaser base type], it could affect certain alloys.
This is something that i have been looking into alot recently.. with little results
Cleaning off baked on oil under cam covers is the main reason i needed this info.
1st try - Kenco water based degreaser mixed 1 part to 20 parts water - worked but not well enough after soaking for 48 hours. These are cast alloy cam covers and at this mix, no corrosion present.
Trying to get a hold of parts cleaner fluid, but cannot find this in any retail store and my Mech has it for $60 for 20L (brand unknown to me)
Spoken with a polisher who is getting in some new stuff to try, but thats $150 per 20L - so will wait for results from them
Currently left the parts with my Machinist to run in his engine bath setup - get them back tomorrow and see how they turned out.
Carbie Cleaner worked awesome, but not very cost effective to use the cans of that @ about $20 a can. i think i recall someone telling me about getting tubs of this stuff, that they soak carbies in, but depending on the parts size and how often you use it, this might be overkill
Kero - kero and diesel works, MR 30 - how is the smell of the shop area you use this in? is it individual parts or setup in a parts washer?
i use R55 solvent. it cleans really good and dries almost instantly and then you can pretty much eat off the product you've washed. if you get dermatitis or other skin irritations but DO NOT USE IT it'l f**k your hands up. then if its gona sit for a while light coat of oil
citrus cleaner followed by penetrant oil to make sure it don't rust while you have things in the open.
What type of citrus cleaner? and where from?
Where would you purchase this?
if it dries quick, then it will flash dry if kept in a parts washer ?
baked on oil.. the absolute best thing i have ever used is subaru upper engine cleaner.. however this stuff is abotu $20 a tin and it works great spray on baked on oil.. scrub with tooth brush or brush of somesort than wash it off with water and brings it up like new.
Edited by rb26s13
I've heard of saoking in diesel, but I seem to remember that you had to be careful how long you soaked it for.......
Also soaking in...........molasses [or a water based mixture of] of all things. Apparently this works [i've never tried it] but rumour has it it will eat alloy=====NOTE: This is only a word of mouth method, I've never used it, it may come up on the www.
R55 solvent you can get from most oil companies. we buy it in 44 galon drums and it costs bout $4 a litre. we also have a parts washer at work an use a water an hvy duty soap to wash stuff an that comes up pretty clean also
I bought "Low Odour Kero", was about $18 for a 4 litre drum from Bunnings. I just cut a 20 Litre drum in half and soak larger parts in there and have some smaller cake tin size ones for smaller parts. Use a scouring pad to get the muck off.
Some good points of kero is: it doesn't evaporate, its not highly flamable, after use you can strain it and re-use it.
For larger aluminum parts which are stained and corroded (like say my inlet manifold), i couldn't really do much, took it round a few engine builders and none of them have a bath suitable for aluminium, tried another place, which from their ad in the yellow pages looked really good, however they have always been closed whenever I called or visited.
I resorted to then getting it bead blasted and plated, which originally I didn't want to do, but after speeking with them and seeing their work it was a good move. Costing rounghly $200 for manifold/plenum and fuel rail. This won't stain/corrode etc and it doesn't look half bad either. Will post pics when I get it back.
I had previously used brake cleaner and carby cleaner, but its not exactly practical for the price and I like my lungs the way they are.
we buy it from leader lubricants or some business like that in perth. before that we bought it from fuchs. ive been using it for 5 years now all it does is dry your hands out but if your use that hand blocker cream or moisturiser or wash your hands with natural soap its ok. when its really dirty it makes my hands itchy. in winter its f**ked to use cos it just soaks in the cold and in summer it evaporates heaps quick. as i said in an above post DO NOT USE IF YOU GET SKIN IRRITATIONS EASILY..
sweet cheers mate
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
