yo
how u all doin.
well recently im finding my P/S pump to be making rattling sounds when i drive it for a while. or when i drift it. the resivour is normally too hot to touch when this problem occurs..
fluid colour is a brownish red. i normally use dexron III.. i just added 100ml of nulon (think thats the brand) with stop leak just incase.. it was running low..
now my question is. what fluid do you guys use when out at the track.?
should i fit a cooler..? perhaps an auto skyrine tranny cooler
do the resivour beanies ppl use (drifters) lower the heat..
i also have a S/Steel manifold.. barely and shielding on the turbo and standard raised bonnet so gets quite hot underneath there.
thanks
mark.
https://www.sau.com.au/forums/topic/187820-powersteering-fluid-boiling/
add a cooler, takes about an hour and is soo simple. use a r33 auto trans cooler i think i paid 20 bucks for the one on our car.
http://www.skylinesaustralia.com/forums/in...st&id=98440
http://www.skylinesaustralia.com/forums/in...st&id=98439
The quick fix is to install a cooler. Which is also the best fix. Get yourself a small (say 100mm x 200mm) radiator & plumb it into the power steering circuit. Some Nissans (not sure what you have) already have an inadequate finned tube arrangement infront of the radiator. Rip that out & replace it with hose & the small cooler.
Job done.
As for fluid. If is smells & is browm replace it. Just use any old gear it doesn't matter.
and no the beanie does not cool the resevoir. lol. it's to soak up spills and prevent those oil spills from starting fires on your exposed manifold. which I would highly reccomend you do something about heat shielding.
Where on a 32GTR do I pull the lines to the cooler, and the return line?
Also, when you plumb up a cooler, do you need to bleed the Power Steer, or is it a self bleeding system?
diagrams for a dumb ass are useful too :D
32gtr has the cooling loop in front of the AC core. If you are fitting a proper cooler then it's just a matter of removing the hoses at each end where they go through the radiator support next to the drivers side headlight and running new lines from there, then ripping out the factory loop.
Then just top up the fluid, start the car and turn the steering wheel from lock to lock for a while, checking the fluid level as you do and topping up as necessary. When it stops making odd noises you are done.
Thanks dave - that's what I though re where to tap it.
I had a look at the service manual last night - just wasn't sure how to bleed it up.
Cheers
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
